To create a new user:
A role is a collection of capabilities. Each user can be assigned multiple roles (in which case the capabilities in each role are additive). The user's role is specific to an Environment, so if you have more than one, you can assign different roles to the same user in each Environment.
You can create your own roles and assign capabilities to them. Users with the 'Manage Roles and Permissions' capability can create roles and modify capabilities for existing roles.
To view and manage roles:
For example, if you want to restrict access to who can download CSV files, you can create a 'CSV downloader' role with a single capability of 'Download data' (and if required, remove it from the 'Administrator' and 'Designer' roles).
You can restrict users who can add new roles: select the Only allow role managers to assign option and add one or more users to the Managers list. Only users in this list will be able to assign this role to other users.
If this option isn't selected for a role, users with the 'Manage Users' capability will also be able to assign that role to users. For example, you may want to restrict who can apply the Administrator role to users.
A capability is an operation that you can assign to a role. You can assign one or more capabilities to a role, as required.
| Permission | Group | Users with this capability in their role will be able to: |
| Access Designer Interface | General | Log into Data Studio as a Designer user. Without this capability, any user will only have access to the simplified Data Consumer interface. If a role is given this capability then enabled users assigned to that role will be deducted from the Designer license limit. Otherwise they will be deducted from the Consumer count. |
| Create and Edit Spaces | General | Create new Spaces, and edit Space details (including assigning access to the Space for other users). |
| View Datasets | Dataset Management | Access Datasets, and create Datasets by loading files or External system sources. Without this capability Datasets can only be created using the Take Snapshot step, but even then they will not be visible. |
| Create and Edit Datasets | Dataset Management | Edit the details of an existing Dataset and add a new Dataset, either in the Datasets screen or by using the Take Snapshot step. Without this capability new batches of data can still be added to an existing Dataset. |
| Upload Dataset file | Dataset Management | Uploaded their own files when creating or updating a Dataset. Without this capability Datasets can only be created from External systems, files in the Server import directory, or from the Take Snapshot step. |
| Create and Edit Views | Dataset Management | Edit, clone or share existing Views, or create a new View. |
| Create and Edit Charts | Dataset Management | Create, edit, clone or share existing Charts (outside of Workflow) |
| Create and Edit Data Tags | Dataset Management | View the list of existing data tags, create new tags, and manage training datasets for tags. |
| Download data | Dataset Management | Use the Download as CSV button from all data grids, and download files exported by a Workflow in the Job screen. Also copy from selected cells in the grid. Data Consumers can be assigned this capability. |
| View Workflows | Workflow Management | Access Workflows and create a new Workflow. |
| Create and Edit Workflows | Workflow Management | Create or edited Workflows. If the capability is removed workflows are always read-only. |
| Execute Workflows | Workflow Management | Execute workflows manually, via a schedule, or using the REST API. |
| Monitor Workflows | Workflow Management | See the Jobs button in the side menu, and therefore view workflow progress and workflow execution details. |
| Create and Edit Workflow Step Settings | Workflow Management | Access Workflow Step settings to view or edit them. Without this capability Step settings can still be used in workflow steps. |
| View Functions | Function Management | View or edit user defined Functions, and include a Function in a Space that is shared from another Space. Without this capability system and user defined Functions can still be used in Workflows and Views. |
| Create and Edit Functions | Function Management | Create new user defined functions and manage existing ones. Without this capability functions cannot be made re-usable. |
| Create and Edit Function Categories | Function Management | Create new function categories and edit or delete existing ones. |
| View External Systems | Integration | View the list of External systems. Without this capability data cannot be loaded into a Dataset from an External System |
| Manage Connections to External Systems | Integration | Create new External systems and edit details for existing systems. Without this capability data can still be loaded from an External system if the user has been assigned valid credentials. |
| API access | Integration | Create and manage REST API keys, and authorize with the REST API. |
| Publish Metadata Changes | Metadata | Allows Workflows, Views and Functions to be published. Without this capability, objects can only be in the Draft state. |
| Export Metadata | Metadata | Allows metadata and data to be exported from a Space to a .dmx or .dmxd file. |
| Import Metadata | Metadata | Allows metadata and data from a .dmx or dmxd file to be imported into a Space. |
| Synchronize Metadata Between Environments | Metadata | Allows metadata and data from a .dmx or dmxd file to be synchronized with a Space. |
| View Schedules | Automations | Access the list of Schedules. |
| Create and Edit Schedules | Automations | Create new Schedules, and view and edit the details of existing Schedules. Without this capability Schedules can still be Run Now. |
| View Automations | Automations | Access the list of Automations. |
| Create and Edit Automations | Automations | Create new Automations. View and edit the details of existing Automations, including enabling or disabling them. |
| View Custom Events | Automations | Access the list of Custom Events. Without this capability Custom Events cannot be selected in the Fire Event step. |
| Create and Edit Custom Events | Automations | Create new Custom Events. View and edit the details of existing Custom Events. |
| Manage Users | Security | Create and edit users. Assign users to a role, unless that role only allows the role managers to assign it. |
| Manage User Groups | Security | Create new groups of users, assign users to groups, and view and manage existing groups. |
| Manage Roles and Permissions | Security | View the list of roles, and the capabilities that make up the role. Create new roles and edit existing roles, including assigning capabilities. |
| Change All Users' Passwords | Security | Reset any other user's password. |
| Manage Authentication Type | Security | Change a user's authentication mechanism, for example from Internal Authentication to LDAP Authentication. |
| Manage Communication Settings | System Settings | View and configure the server's port, certificate, and SMTP properties. |
| Manage System Settings | System Settings | View and configure system defaults for warnings, connections to external services, server time zone, and system metrics logging. |
| Manage Data Handling Settings | System Settings | View and configure data display settings. |
| Manage Data Loading Settings | System Settings | View and configure loading and auto tagging settings. |
| Manage Performance Settings | System Settings | View and configure data load and processing performance settings. |
| Manage Security Settings | System Settings | View and configure session, password policy, and authentication settings |
| Manage Workflow Step Settings | System Settings | View and configure remote Find duplicates server URL and other step-specific settings. |
| Manage Storage Settings | System Settings | View and configure file storage purge settings. |
| Manage Product License | System Settings | Allows a license update key to be retrieved and license update codes to be applied. |
| View System Information | System Settings | Allows access to the Metrics Operations endpoints in the REST API (assuming a valid API key is also provided). |
| Create Key Encryption | Data Encryption | Access the Data encryption system settings |
| Manage Issue lists | Issue Management | Create, update, delete Issue lists |
| View and Update Issues | Issue Management | Access an existing lists of issues, update an issue and add comments. Consumer users can have this capability |
