This maintenance release includes updates to dependent libraries for security purposes, as well as the underlying APIs of the Find duplicates step.
Note that this release is for the Windows installer only (the Linux build is unchanged).
This maintenance release adds email validation to two-factor authentication, a fix to download authentication and updates to dependent libraries for security purposes.
This maintenance release resolves several issues with workflow execution and performance, and makes updates to many workflow step libraries for security purposes.
This maintenance release resolves several issues with workflow execution using the Data Studio REST API.
This maintenance release resolves several issues with memory usage and locking at high load as well as a range of issues in the workflow builder, workflow step and data connections.
This release introduces new features, existing functionality enhancements, performance improvements and a number of bug fixes.
This maintenance release resolves workflow and custom step backward compatibility issues as well as bugs that caused incorrect workflow results.
Download Data Studio 1.5.0 for Linux.
Dependencies updated as part of this release:
This release resolves an issue where changing the path for the database location (root or data) during Windows installation caused the Find duplicates workflow step to fail and appear to be unlicensed when the Match server is run within Data Studio. This was due to an invalid file being created when the match store location was changed by the installer.
This release is for the Windows installer only (the Linux build is unchanged). If you have v1.4.0 installed, there's no need to upgrade to this version.
If you are having issues with the Find duplicates step, please contact us.
Download Data Studio 1.4.0 for Linux.
Multi-Column chooser property.Custom blocking keys and rules created for the previous version of Match or Data Studio will not be compatible with this version without making the following change: remove the maxBlockSize entry from all blocking key definitions.
Note that the default rules and blocking keys supplied with Data Studio have already been updated and will work out-of-the-box.
This maintenance release fixes a number of bugs, including significant performance improvements to the Harmonize duplicates and Use snapshot steps.
We've also made a range of improvements to information available in the audit log as well as the Salesforce and Google BigQuery connections.
Download Data Studio 1.3.2 for Linux.
This maintenance release fixes a number of bugs, including significantly speeding up the workflow builder UI, as well as introducing features to support hosting Data Studio as a single-tenant managed service. Download Data Studio 1.3.1. Download ODBC drivers 1.3.1. Download Data Studio 1.3.1 for Linux.
This release introduces several new features and a number of bug fixes. Download Data Studio 1.3. Download ODBC drivers 1.3. Download Data Studio 1.3 for Linux.
This release introduces multiple brand new features, existing functionality enhancements, performance improvements and a large number of bug fixes.
Download Data Studio 1.2.
Download ODBC drivers 1.2.
This release fixes a high priority bug in the join engine that occurred when using key columns containing more than 100,000 unique values of mixed data types. Download Data Studio 1.1.5. Download ODBC drivers 1.1.5.
This release includes a number of high priority bug fixes and a few minor new features. Download Data Studio 1.1.4. Download ODBC drivers 1.1.4.
This release includes a number of high priority bug fixes. Download Data Studio 1.1.3. Download ODBC drivers 1.1.3.
This release includes a number of high priority bug fixes as well as several new features. Download Data Studio 1.1.2. Download ODBC drivers 1.1.2.
Database
Profiling
Grouping
Transform step
Validate and Join steps
Lookups
Workflow Designer
Character encoding
Snapshots
Scripting
User management
UI
SQL Server
Date/time/time zone
ODBC
This release includes a number of high priority bug fixes. Download Data Studio 1.1.1. Download ODBC drivers 1.1.1.
Database
Profiling
Grouping
Lookups
Split step
Workflow Designer
Snapshots
User management
UI
JDBC
This release includes new CDM steps, bringing data matching as well as address and email validation into Aperture Data Studio.
We've also fixed a large number of bugs, added the ability to track data quality over time, publish to ODBC clients, extended the functionality in the SDK and much more.
Profiling
Grouping
Find Duplicates step
Validate Emails step
Lookups
Snapshots
User management
Licensing
UI
JDBC
This release includes various improvements and bug fixes.
This release includes product name change as well as various improvements and bug fixes.
This is the first release of Aperture Data Studio.
