Define your business terminology, create data tags/scripts and other objects used by workflow steps. You can also view and edit the blocking keys and rulesets for the Find duplicates step.
The constants area shows the existing constant libraries. You can view the standard business constants installed with Data Studio or create your own. The business constants supplied are regular expressions that can be used in transformations to verify the format of commonly found data fields. You can also create and define your own business constant libraries to use in transformations or with custom steps.
Events are occurrences/triggers in Data Studio, such as a workflow completing. Each event contains event information - event data items (e.g. the workflow name).
You can set up email notifications to be sent to you/other recipients when certain events have been published.
There are two types of events:
These are events that occur in Data Studio. The following system events (and the related data items) are available:
| System event name | Available event data items |
| Workflow started | CURRENT_USER_EMAIL CURRENT_USER_NAME WORKFLOW_ID WORKFLOW_JOB_ID WORKFLOW_NAME WORKFLOW_START_TIME |
| Workflow completed | CURRENT_USER_EMAIL CURRENT_USER_NAME WORKFLOW_COMPLETION_TIME WORKFLOW_ID WORKFLOW_JOB_ID WORKFLOW_NAME WORKFLOW_START_TIME |
| Workflow failed | CURRENT_USER_EMAIL CURRENT_USER_NAME WORKFLOW_ERROR_MESSAGE WORKFLOW_ERROR_TIME WORKFLOW_ID WORKFLOW_JOB_ID WORKFLOW_NAME WORKFLOW_START_TIME |
| Workflow shared | CURRENT_USER_NAME EVENT_TIME WORKFLOW_ID WORKFLOW_NAME |
| User created | CREATED_USER_NAME CURRENT_USER_NAME EVENT_TIME |
| User deleted | CURRENT_USER_NAME DELETED_USER_NAME EVENT_TIME |
| License expiring | LICENSE_DAYS_REMAINING LICENSE_EXPIRATION_DATE LICENSE_NAME |
| Low disk space (the default is 10% but you can change that in Configuration > All server settings > Disk space free warning threshold) |
DISK_SPACE_PERCENTAGE EVENT_TIME |
| All events (includes custom events) | See individual events for available data items. |
These are events that you can create depending on your business requirements. In addition to the event data items you've created, the following items will be available for all custom events:
| Event type | Available event data items |
| Custom event | WORKFLOW_ID WORKFLOW_NAME PREVIOUS_STEP_NAME NEXT_STEP_NAME EVENT_TIME CURRENT_USER_NAME CURRENT_USER_EMAIL |
To create a custom event, go to Glossary > Custom events and click Create a new custom event.
For example, if you want to create a custom event that is fired when the Validate step has failures, you could create a custom event with the name 'Validation failed' and an event data item named 'Reason'. Once used in the Fire event step, different values for the event data item (Reason) can be provided.
To publish a custom event, use the Fire event step.
You can create new and manage existing data tags using Glossary.
This contains the default blocking keys used by the Find duplicates step. You can't change the default set but administrators can create their own keys to customize the behavior of the step.
This contains the default rulesets used by the Find duplicates step. You can't change the default ones but administrators can create their own rulesets to customize the behavior of the step.
You can receive email notifications when a particular system or custom event occurs in Data Studio (e.g. a workflow has completed).
To create a notification, go to Glossary > Notifications and click Create a new notification.
Administrators can configure the SMTP server settings by going to Configuration > All server settings > SMTP Properties.
Once set up, click Test SMTP Configuration (in All server settings) to test the connection.
The scripts section allows you to define scripts that can be used by the Script steps in a workflow. Scripts have to be added to a script library.
To add a script library, click Create a new script library, enter a name of the library, a description (optional) and click Okay. Note that script libraries can be deleted only when they are empty.
All scripts have to be added to an existing library. To add a new script, click on the required library then click Create a new script. Scripts require a unique name, the area of use, indication of whether they can output logging to a file, the language type and the script code. The script definition can optionally also have parameters to change the script's behavior.
