A container is a standard unit of software that packages up code and all its dependencies so the application runs quickly and reliably from one computing environment to another. Docker is the chosen container platform to produce container images for Aperture Data Studio. Docker container images are available for both Linux and Windows-based applications. Containerized software will always run the same, regardless of the infrastructure.
The diagram above illustrates the topology of the Data Studio Container suite in a Linux machine.
Electronic Updates (EU) feeds the latest reference data to Data Studio which is used by the Validate addresses step. The user either needs to have a Windows environment to use the Windows client provided or implement their own integration using the REST API.
Following are the exposed volumes which can be mounted to the host machine:
Set up files and folders
This step will only need to be run once and can be skipped for subsequent upgrades. You will need to execute setup.sh which will provision all the required volumes in the host machine required for the Data Studio Docker container. The folders and files are
The setup.sh also will create the Experian user and assign to the folders above. Experian user is required by Data Studio Docker container for read/write purposes.
You may modify the location of the volumes in the setup.sh and docker-compose.yml file. For example,
mkdir -p <new host directory>/addons
Load images
There are 3 images which assemble the whole Data Studio v2 suite: Data Studio, Find Duplicates, and Find Duplicates Workbench. To load these images, you can either perform one of the following steps:
sudo docker load -i datastudio-<VERSION>-docker.tar.gz
sudo docker load -i find-duplicates-<VERSION>-docker.tar.gz
sudo docker load -i find-duplicates-workbench-<VERSION>-docker.tar.gz
Build, start and stop container with docker-compose
To start the containers, you will need to execute the following command at the folder which contain docker-compose.yml file.
sudo docker-compose up -d
Following are the content of docker-compose.yml. Let's analyze the code line by line.
version: "3"
services:
datastudio:
image: "experian/datastudio:2.0.15.178987"
ports:
- "7701:7701"
- "7801:7801"
volumes:
- /opt/ApertureDataStudio/.experian:/opt/ApertureDataStudio/.experian
- ./ApertureDataStudio:/ApertureDataStudio
- ./ApertureDataStudio/server.properties:/opt/ApertureDataStudio/server.properties
- ./ApertureDataStudio/addons:/opt/ApertureDataStudio/addons
- ./AddressValidate/qawserve.ini:/opt/ApertureDataStudio/addressValidate/runtime/qawserve.ini
- ./AddressValidate/qaworld.ini:/opt/ApertureDataStudio/addressValidate/runtime/qaworld.ini
- ./AddressValidate/batchData:/opt/ApertureDataStudio/addressValidate/runtime/batchData
find-duplicates:
image: "experian/find-duplicates:2.0.15.178987"
ports:
- "8080:8080"
volumes:
- ./ApertureDataStudio/experianmatch:/home/experian/ApertureDataStudio/data/experianmatch
find-duplicates-workbench:
image: "experian/find-duplicates-workbench:2.0.15.178987"
ports:
- "8090:8090"
volumes:
- ./ApertureDataStudio/experianmatch:/opt/FindDuplicatesWorkbench/experianmatch
The datastudio
service:
- The address validate reference data directory (batchData in the example above) is to be created and *docker-compose.yml* file is to be configured by the user.
- The number of subdirectories in the address validate reference data directory depends on the number of countries subscribed by the user.
- Data Studio requires access to local resources to create index files during Workflow execution. Data Studio might be accessing or creating multiple index files per execution depending on the workflow complexity and used steps. Hence, you can enhance *Ulimits* to allow Data Studio accessing higher volume of local resources per execution. This can be set through *soft* (mininum limit) and *hard* (maximum limit) values. For example:
yml
ulimits:
nofile:
soft: "1048576"
hard: "1048576"
- You can also specify the memory usage for `datastudio` service through the YAML file. For example
yml
command: "java -Xms4G -Xmx32G -jar servicerunner-2.2.2.jar STARTUP"
The above command starts Data Studio v2.2.2 with memory usage between 4GB and 32GB.
The find-duplicates
service:
datastudio
service.find-duplicates
section.yml
<host directory which contains the KB>:/opt/Standardize/Data
The find-duplicates-workbench
service:
find-duplicates
service. You can remove any of the unused services from docker-compose.yml.
[Optional] To stop the containers, you will need to execute the following command at the folder which contain docker-compose.yml file.
shell
sudo docker-compose down
To upgrade Data Studio, download the new version of Data Studio (container image and setup files) and repeat steps 2 & 3 in the section above.
The newly downloaded load-image.sh and docker-compose.yml should reflect the new Data Studio version so no modifications are required.
For Red Hat Enterprise Linux 8 (RHEL8), please use commands below to get newer version.
sudo yum module enable container-tools:rhel8
sudo yum module install container-tools:rhel8
Load images
podman load -i datastudio-<VERSION>-docker.tar.gz
podman load -i find-duplicates-<VERSION>-docker.tar.gz
podman load -i find-duplicates-workbench-<VERSION>-docker.tar.gz
This step will only need to be run once and can be skipped for subsequent upgrades. You have to execute the setup-podman.sh, which will create all the required files and folders in current folder.
chmod +x setup-podman.sh
./setup-podman.sh
Create pod and containers
The create-pod-containers.sh will create a pod named "datastudio-pod" and 3 containers from the loaded container images.
chmod +x create-pod-containers.sh
./create-pod-containers.sh
If "datastudio-pod" already used by existing pod, you have to remove the existing pod by running script below:
chmod +x remove-pod-containers.sh
./remove-pod-containers.sh
Manage pod
shell
podman pod ls
shell
podman pod start datastudio-pod
shell
podman pod stop datastudio-pod
The newly downloaded load-images-podman.sh and create-pod-containers.sh should reflect the new Data Studio version so no modifications are required.
Secure Sockets Layer (SSL) can be enabled for Data Studio containers running on Docker or Podman.
To use SSL, you need a certificate. First, get the required certificate and key files. If you don't have them available, use the command below to create two sample files ('example.crt' and 'example.key'):
openssl req -x509 -newkey rsa:4096 -sha256 -days 365 -nodes \
-keyout example.key -out example.crt -subj "/CN=example.com" \
-addext "subjectAltName=DNS:example.com,DNS:example.net,IP:10.0.1.4"
To import a certificate:
chown -R 49082:49082 ApertureDataStudio
environment:
JVM_OPTS: >
-Djavax.net.ssl.trustStore=/opt/ApertureDataStudio/cert/cacerts
We recommend using a Docker NGINX container alongside Data Studio if there's a need for a reverse proxy for SSL termination.
All Data Studio ports are fixed in order to run in a Docker container environment.
As such, mapping to different ports through configuring the docker-compose.yml or nginx.conf files will not work.
To use the standard SSL port 443, this will have to be configured in the server.properties file by adding the following line:
Server.httpPort=443
Communication.useSSL=true
A certificate is required in order to use SSL. The command below will create 2 files: example.crt, example.key. These files will be need to be provided to the NGINX container later.
Create a nginx.conf file with the content below:
server {
listen 443 ssl;
ssl_certificate /etc/nginx/certs/example.crt;
ssl_certificate_key /etc/nginx/certs/example.key;
location / {
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_pass https://datastudio:443/;
Update the docker-compose.yml file to include the NGINX container.
Mount the folder that contains the example.crt and example.key created in the step earlier above to "/etc/nginx/certs".
Mount the nginx.conf created above to "/etc/nginx/conf.d/nginx.conf".
version: '3'
services:
datastudio:
image: "experian/datastudio:2.1.0"
ports:
- "8443:443"
volumes:
- ./AddressValidate/batchData:/opt/ApertureDataStudio/addressValidate/batchData
nginx:
image: "nginx:1.19.0"
ports :
- "443:443"
volumes:
- ./Nginx/certs:/etc/nginx/certs
- ./Nginx/nginx.conf:/etc/nginx/conf.d/nginx.conf
environment:
no_proxy: datastudio
Once the docker-compose up command is run, access with SSL will be enabled.
To ensure Address Validate is properly configured, the following steps are suggested:
sudo docker exec -it <container name> /bin/bash
runtime
folder. LD_LIBRARY_PATH=. ./batwv
