These settings appear in the qawserve.ini file.
Each dataset has its own default address format, which conforms to local standards. For example, the default American address contains the house number followed by the street name, town name, state and ZIP code. The default German address, on the other hand, contains the street name followed by house number, postal code and town name. It is strongly recommended that you do not edit the default address format: if you wish to create a different format to fit your application, you should do so within a new configuration layout.
Settings
It is possible to define address formats for more than one data mapping within a single configuration layout. Therefore, each of the settings in this section must be directly prefixed with the data mapping identifier of the relevant data mapping. For example, the setting CapitaliseItem for an Australia data mapping might become AUSCapitaliseItem. An address format must be set up for each data mapping that you have installed. Data mappings are set up with the DataMappings keyword.
[identifier]AddressLineCount={integer}
This defines the number of lines in the formatted output address. The format of each individual address line is specified with the AddressLineN keyword.
The number of lines you specify should take into account DataPlus information lines that might be returned.
USAAddressLineCount=4
This tells Pro Web to produce formatted output addresses of four lines for the USA.
[identifier]AddressLine[N]=W
Blank
This specifies which address elements should appear on which line. You can add as many AddressLineN lines as you defined with the AddressLineCount keyword, each time replacing N with the appropriate line number. W signifies that the number that follows it is the maximum width of the line in characters, and < element list> is a comma separated list of dataset-specific element codes. By specifying an element code, you force Pro Web to place that element on that line (if the element exists in the matched address).
DataPlus elements are formed from the base name and the element name.
You can allow Pro Web to insert other suitable elements before, after or between fixed elements by using the format specifier "…"
NLDAddressLine1=W40,S11,...
This instructs Pro Web to give line 1 of a Netherlands output address a maximum width of 40 characters. The street name is fixed to the line, and any subsequent elements can also appear on the line if they fit there.
AUSAddressLine6=W40,AUSMOS.Desc
This tells Pro Web to give line 6 of an Australian output address a maximum width of 40 characters and fix the description part of the MOSAIC DataPlus set to it.
Certain DataPlus elements contain imputed information by default. An imputed field is one where data does not exist for all addresses. In this scenario, the gaps in the data are filled in (imputed) using neighbouring data. Alternatively you can specify that you do not want the data to be imputed.
For example:
| GBRWPT.Party | Standard DataPlus item |
| GBRWPT.Party.NotImputed | If there is no available value in the raw data for this DataPlus set for this address, this element will be blank |
| GBRWPT.Party.IsImputed | The value of this item can be either Yes or No. If this item has been taken directly from the raw data, the value is No. Otherwise, the item has been imputed by Experian, and the value is Yes. |
[identifier]CapitaliseItem={element list}
Blank
This keyword defines which address elements should appear in upper case in the formatted address. The value of the keyword is a list of element codes separated by spaces.
CapitaliseItem=P12 X11
Means that the town/city and country name will be capitalised in the output address.
[identifier]AbbreviateItem={element list}
Blank
This keyword defines which address elements should be abbreviated in the formatted address. The value of the keyword is a list of element codes, which differ from dataset to dataset, separated by spaces.
AUSAbbreviateItem=S11
Means that the Australian street name will be abbreviated.
[identifier]SeparateElements={Boolean}
True
This keyword specifies whether or not address elements on a single line are separated, usually by commas. Set this keyword to False if you do not want to comma-separate address elements.
GBRSeparateElements=True
Means that a UK street and locality on the same line would look like this:
Chester Road, Ash
If the keyword was set to False, it would look like this:
Chester Road Ash
[identifier]ElementSeparator={separator sequence}
Blank, but is usually set in the ini file depending on the country.
This keyword defines which address elements should be separated by additional characters in the formatted address.
The format of {separator sequence} is: Element code {prefix separator^suffix separator}.
AUSElementSeparator=C11 { ^ }
Here the element separator would be blank before and after the postcode.
Element separators take precedence right over left. These keywords can be enabled or disabled with the keyword SeparateElements.
[identifier]ElementExtras={element list}
Blank
This keyword places additional characters around an address element. The format of {element list} is: Element code {extra characters^extra characters}.
ESPElementExtras=L21{(^)}
The above example places brackets around element L21 (Spanish province in this case).
[identifier]TerminateLines={Boolean}
False
This keyword defines whether or not certain address lines are ended with a comma.
GBRTerminateLines=True
This means that a five-line UK address could look like this:
6 Cedar Grove,
Bisley,
WOKING,
Surrey,
GU24 9EF
If the keyword was set to False, the commas would not appear.
[identifier]ExcludeItem={element list}
Blank
This keyword prevents an item from appearing in an address if it is not fixed to a particular line.
DEUExcludeItem=C11
If the postcode has not been fixed to a specific line, then it will not appear in the address, even though it is in the list of default address items.
[identifier]FlattenDiacritics={Boolean}
No
This keyword enables you to replace all diacritic characters, such as accents and umlauts, with their non-diacritic equivalents. For example, the Danish address "Degnsgårdvej 1 7840 Højslev" would change to "Degnsgardvej 1 7840 Hojslev" if the FlattenDiacritics keyword is set to Yes.
ESPFlattenDiacritics=Yes
This means that all diacritic characters, in returned Spanish addresses, will be suppressed by Pro Web.
[identifier]CDFVariation={Integer}
This keyword tells Pro Web which Form of address to use when automatically fitting address element into the returned address. This is for datasets which include more than one Form of address, such as the Netherlands, Belgium and Finland datasets.
NLDCDFVariation=2
This example selects the second Form of address for the Netherlands dataset. The three Forms of address for Netherlands addresses are Official, NEN and TPG, so this setting would apply the NEN form to your output addresses.
[identifier]Comment={text string}
Default View
This allows you to add a comment to a layout, which is displayed at the bottom of the Select Layout dialog.
GBRComment=Custom Layout for the United Kingdom
[identifier]MultiValueDPSeparator={String}
This allows you to set the delimiter used to separate returned multiple DataPlus values.
GBRMultiValueDPSeparator=|
[identifier]CapitaliseUnused={String}
No
This allows you to change the case of unmatched leading information.
AUSCapitaliseUnused=No
This setting applies to CAN data only.
[identifier]SubPremiseFormat={value}
Prepend, Separate
No value
When the 'prepend' value is used, this setting standardizes the sub-premise formatting for Canadian addresses to follow Canada Post preferred address formatting requirements. I.e. the address will be displayed using the 'sub-premise'-'premise' format. When the 'separate' value is used, the address will be displayed using the premise street sub-premise format.
Value
When no value is specified, the sub-premise will be displayed based on the default Canada address formatting rules.
SubPremiseFormat=prepend
108-815 Main Street
SubPremiseFormat=separate
815 Main Street Apt 108
Applicable to…
[identifier]UseExtendedRetention={Boolean}
False
This keyword specifies whether or not extended retention capabilities are enabled.
"Extended retention" refers to advanced functionality for detecting unmatched input text and putting it into one or more address elements. These elements can be fixed to address layouts like other additional elements. Depending on the country, the following address elements will be available:
| Code | Retained element | Description |
| U11 | Retained sub-premise | This element code is used to retain any unmatched information relating to sub-premises. This includes some apartments and suites which may not appear in the Postal Address File, but which may be needed for successful mail delivery. |
| U21 | Retained 'care of' form | This element code is used to retain any unmatched 'care of' information. For example, an address may feature a phrase such as 'care of Mr. Holiday'. In such cases the text 'care of' is retained in this element code, as is any unmatched text that follows it. |
| U31 | Retained pre-street info | This element code is used to retain any other unmatched information that is found before the first matched text. This element code allows the capture of such phrases as 'round the back' - which could be important for successful delivery of mail. |
| U41 | Retained post-street info | This element code is used to retain any unmatched information that is found after the Street element (provided it does not match certain excluded strings). |
Note
| U21 | Retained secondary number | This element is used to retain any unmatched numbers found before a matched premise. If you include this element in a layout so that it precedes the premises number (P11) it will be followed by a hyphen. For example, '11-26 Sloane Avenue…' will be returned even if the search address was '11 26 Sloane Avenue…' |
| U31 | Identifiable pre-street information | This element is used to retain any recognizable address information preceding the Street element. For example, an address may feature a phrase such as 'care of Mr. Holiday'. In such cases the text 'care of' is retained using this element code, as is any unmatched text that follows it. |
| U41 | General pre-street information | This element is used to retain any other unmatched information that is found before the first matched text. This element code allows the capture of phrases such as 'round the back' - which could be important for successful delivery of mail. |
| U51 | Post-street information | This element is used to retain any unmatched information that is found after the Street element (provided it does not match certain excluded strings). |
Note
| U11 | Retained pre-leading information | This element is used to retain any unmatched information that is found before the first matched text. This element code allows the capture of phrases such as 'round the back' - which could be important for successful delivery of mail. |
Note
AUSUseExtendedRetention=True
Note
