Intuitive configuration
You can configure how your Intuitive suggestions are formatted.
Format:
IntuitiveSearchMaxPicklist={Maximum picklist size}
Default:
10
Purpose:
This defines the maximum picklist size that can be returned by the Intuitive Search engine, however, this can be overridden by the Threshold setting. There is no maximum value for this setting.
If the Intuitive Search engine returns more results than the set value, then the lowest-scoring addresses will be removed from the flattened picklist. In the instance of equally scoring addresses being returned, then the picklist will be truncated to the value defined.
Example:
IntuitiveSearchMaxPicklist=100
Format:
[identifier]EnableEnhancedLayout={String}
Default:
Yes
Purpose:
This allows you to prepend unmatched leading information to address lines.
This setting will only take effect if the UseExtendedRetention setting is not enabled.
Example:
AUSEnableEnhancedLayout=Yes
Format:
[identifier]DisplayEnhancedInfoOnPicklist={Boolean}
Default:
Yes
Purpose:
This defines whether any leading unmatched text before the actual address elements are retained in the picklist.
This setting will only take effect if the EnableEnhancedLayout setting is set to "Yes".
Example:
AUSDisplayEnhancedInfoOnPicklist=Yes
Format:
EnableUnvalidatedFormatting={Boolean}
Default:
True
Purpose:
If enabled, this setting allows the Intuitive Search engine to bypass the capturing of an address and standardise the elements in the input line. An uncaptured address can be automatically classified into its Street, Locality, State and Postcode elements.
Example:
EnableUnvalidatedFormatting=True
This setting must be set to True for the classification of an address to be performed.
This keyword applies to Australia, New Zealand and FRX data only.
Format:
MatchToInBetweenRangeNumber={boolean}
Default:
True
Purpose:
This keyword is used to determine whether an input will match to a range of addresses - for example, whether 17 High Street will match to 13-26 High Street, given that the rest of the address is the same.
Example:
MatchToInBetweenRangeNumber=true
This tells Pro Web that it should match an input that is found in a premises range.
The following settings relate to intuitive picklist configuration. They will work in conjunction with and be applied per layout:
Format:
IntuitiveAddressLineCount={Integer}
Purpose:
Defines the number of lines in the Intuitive picklist. To enable the setting, the value has to be set to 1. The address elements are specified by IntuitiveAddressLine1
Example:
IntuitiveAddressLineCount=1
Format:
IntuitiveAddressLine1=W,
Purpose:
Specifies the address elements that will appear in the Intuitive picklist.
W signifies that the number that follows is the maximum width of the line in characters.
is a comma separated list of dataset-specific element codes. By specifying an element code, you force Pro Web to place that element on that line (if the element exists in the matched address).
Example:
IntuitiveAddressLine1=W160,U21,...,C11
Format:
IntuitiveElementSeparator={Default separator} {Element code {separator}}
Purpose:
Specifies which address elements should be separated by additional characters in the Intuitive picklist.
You can specify the element separator for individual elements using {separator}.
The format is: {prefix separator^suffix separator} where ^ is the value for that element.
Note that {separator} will override {Default separator} for the specified elements.
Example:
IntuitiveElementSeparator={ } P11{, ^} L31{, ^} L11{, ^ } C11{, ^-}
Format:
{Country 3 letter ISO code}VirtualPicklist={Yes/No}
Default:
False
Purpose:
This option activates for Intuitive engine creation of virtual picklist elements based on dataplus file.
The Virtual Picklist Feature is implemented in Pro Web 7.73 and shall work only in the New Zealand DataFusion set with the NZLPHY dataplus file. When enabled, the feature shall return Physical Addresses based on the Rural Delivery address search.
Example:
NZDVirtualPicklist=yes
