User-defined layouts can be used to specify the number, content and format of the address output columns.
When a custom layout is defined in the Experian Batch API qaworld.ini config file, a "Custom" option will be available in the Additional options menu, in addition to the "Standard" (7-column) and "Component" (28-coloumn) default layouts.
To create a custom layout, navigate to addressValidate\runtime folder in the Aperture Data Studio installation directory (by default C:\ProgramData\Experian\addressValidate\runtime) and edit the qaworld.ini file using a text editor.
The custom layout has to be named [CustomISO]
, where "ISO
" matches the country base name, and only one of these can be defined per country data set.
Once you've created a custom layout, we recommend checking that it is valid and correct using the BATWV64.EXE test harness before using it in Data Studio.
We also recommend that you restart the Data Studio service after adding or updating a custom layout.
Here's an example of a custom layout that will return a 5-column output with:
[CustomGBR]
CountryBase=GBR
CleaningAction=Address
GBRAddressLineCount=5
GBRAddressLine1=W100,O21,O11
GBRAddressLine2=W60
GBRAddressLine3=W60,L21
GBRAddressLine4=W60,L11
GBRAddressLine5=W60,C11
You can define custom labels for each address line. These labels can then be used as column names for the cleansed address output from the Validate addresses step.
To define a label for an address line, add the label text prefixed with a "T" before specifying the address element.
Here is an example of a custom layout with line labels specified:
[CustomGBR]
CountryBase=GBR
GBRAddressLine1=W100,TBusiness information,O21,O11
GBRAddressLine2=W60,TPremise detail
GBRAddressLine3=W60,TTown,L21
GBRAddressLine4=W60,TCounty,L11
GBRAddressLine5=W60,TPostcode,C11
To return addresses in a CASS certified layout with DPV information, the layout should include the following settings:
Certification=True
CompatibilityFormatting=False
