The Data Studio license enables a set of functionality in the application. The license is made up of multiple licensed features, allowing you to choose exactly what functionality to enable.
Only users with the "Manage Product License" capability in their role can view and update the license.
To check what license you have and see what features it enables:
On this page you can see:
There are several reasons for updating your license:
When you request a license, you will be asked to provide the unique update key generated by your specific Data Studio deployment. Using the update key and the license requirements, Experian will generate an update code to be applied in Data Studio.
To get the update key or apply an update code, click the user icon in the top menu and select Update license.
The audit code encodes Data Studio's current license including any additional features. You may be asked to provide this to Experian to ensure the application is correctly licensed.
To get the audit code:
Rows per table is the maximum number of rows that a single Dataset can have. For a multi batch Dataset, the total number of rows is the sum of all rows in all batches. This limit applies to all Datasets, including Snapshots.
Number of data sources is the number of Datasets that can be loaded into Data Studio. Data loaded from files, database tables, or created in a Workflow (as a Snapshot) all count as Datasets. The limit applies to the sum total of all Datasets in all Spaces and Environments within your deployment.
Data connection - All allows Data Studio users to set up External system connections to any of the supported system types. If this is not enabled in the license, separate features can be used to enable specific connection types:
SFTP connections are available for all license editions.
The user license limits apply to enabled users. If a user is disabled, their Space, permissions, and settings are retained but they are not able to log in and no longer count towards the license limit. You may create as many users as you wish and enable/disable them selectively as required.
Data Consumer users is the number of Consumer users that can be enabled at any point in time with a role that has no defined capabilities. Consumer users typically interact with reports generated by Data Studio Workflows.
Administrator / Designer users is the number of users that can be enabled at any point in time with a role that at a minimum includes the 'Access Designer interface' capability. Any user managing data, creating Workflows, or carrying out user administration will be an Administrator / Designer user.
The super admin user is always available and doesn't contribute to the total Administrator / Designer user limit.
Non native add-on steps indicates whether Workflow steps and parsers built using the Data Studio SDK, also known as custom steps and custom parsers, can be used in the deployment.
Where custom steps or parsers are included as part of a Data Studio deployment, the About Aperture Data Studio page will also list the name, version, developer and the assigned license type.
