Manage users, configure workflow steps and specify product settings.
System settings
These allow you to customize Data Studio. You can specify:
- All server settings
- Communication
- Data handling
- Loading
- Security
- Storage
- System
Find out about how to change the database location or add a SSL certificate.
Step settings
Configure certain workflow steps and their behavior.
- Enable steps
- Find duplicates
- Validate addresses
- Validate emails
Manage users
All users in Data Studio have to have a role assigned to them.
The following roles are available:
- Consumer
- Designer and developer
- Administrator
Note that these roles can't be modified. In addition, the default administrator user can't be edited or disabled.
| Capability |
Consumer |
Designer and developer |
Administrator |
| Access to Data Explorer |
Yes |
Yes |
Yes |
| Access to Workflow Designer |
Yes |
Yes |
Yes |
| Access to Monitoring |
Yes |
Yes |
Yes |
| Access to Configuration |
Yes |
| Access to Glossary |
Yes |
Yes |
| Create workflow |
Yes |
Yes |
| Delete workflow |
Yes |
Yes |
| Edit workflow |
Yes |
Yes |
| Execute workflow |
Yes |
Yes |
Yes |
| Manage Security |
Yes |
| Update licenses |
Yes |
To create a new user:
- Go to Configuration and click Users.
- Click Create a new user.
- You have to enter the following:
- Username (can contain alphanumeric characters and underscores only)
- Display name (no restrictions)
- Role (choose from one of the three roles)
- Enabled (specify whether this user is active, i.e. able to use Data Studio)
Note that you can add as many users as you want but the number of active users you can have will depend on your license. Once your user limit is reached, you won't be able to set users to Enabled.
You can also group users for easier management by assigning them to teams. Users with the Administrator role will be automatically assigned to the Administrators team, all other users to the Initial group. You can modify this as required.
Authentication mechanism
This is the method of authentication that will be used. The following options are available:
- Aperture Data Studio internal – use this for users requiring access to Data Studio only, without any additional authentication.
- LDAP and MS Active Directory (AD) server – use this to allow users to log in with their LAN IDs (fill in the LDAP username field). If this option is not available, go to Configuration > All server settings and enable LDAP properties. Find out how to configure LDAP.
To manage user details, go to Configuration > Users. Right-click on the required user to edit their details/change password or disable them.
