Address searching
Pro Plug and Go provides a guided, interactive address searching experience that connects directly to a Pro Web server. Users enter search criteria through the client interface, select the appropriate dataset, search type, and layout, and receive validated address results in real time. All search processing is performed by Pro Web, ensuring consistent data quality and centrally managed behavior, while Pro Plug and Go focuses on ease of use and efficient result selection.
Outside the settings dialog, the top toolbar of the application allows users to choose how searches are performed based on the following settings.
Dataset
Select the dataset (e.g., GBR, USA, Australia).
The available datasets are retrieved directly from the connected Pro Web server.
A reference list of supported countries and data assets is available here.
Search type
Search types define the search experience.
Examples from Pro Web include:
  • Singleline
  • Typedown
  • Verification
  • Intuitive
  • CASS (only for the United States)
  • LookUp (the United States and Australia)
  • Keyfinder
Layout
Determines the address formatting template applied to results (e.g., standard layout, custom layouts configured on the server). All layout options are supplied by the Pro Web server and reflect the address‑formatting rules configured centrally.
Each data asset has a default layout known as "QAS Standard Layout".
For more information refer to the search results overview.
Pro Web
Pro Plug and Go
