These settings are found in the server ini file, qaworld.ini.
[identifier]Stage1Prompt={text string}
Varies for each dataset.
This setting and the Stage2MergedTDPrompt setting control the search prompts for Typedown searches. Use this setting to change the prompt for the first stage of a Typedown search. [identifier] is the data mapping identifier for the data mapping with which the custom prompt will be used.
This setting has no effect on searching. It should be used to help users enter the expected information.
USAStage1Prompt=Enter a ZIP Code (e.g. 94109)
This example changes the first Typedown prompt for the USA data mapping to encourage users to only enter a ZIP code, and includes an example.
[identifier]Stage2MergedTDPrompt={text string}
This setting and the Stage1Prompt setting control the search prompts for Typedown searches. Use this setting to change the prompt for the second stage of a Typedown search. [identifier] is the data mapping identifier for the data mapping with which the custom prompt will be used.
USAStage2MergedTDPrompt=Enter street information or PO Box
This example changes the second stage Typedown prompt for the USA data mapping to encourage users to only enter street information or a PO Box.
[identifier]VerIntRequiredPrompt=
Please confirm your address
This setting controls the search prompt for Verification searches which return the Interaction required verification level. You can customise this prompt to assist your users in responding to search results.
[identifier] is the data mapping identifier for the data mapping with which the prompt will be used. If you omit [identifier] the prompt will apply to all data mappings which do not have this setting individually configured.
USAVerIntRequiredPrompt=Please check the address
This example changes the Interaction required prompt for the USA data mapping to "Please check the address".
[identifier]VerPremisesPartialPrompt=
Please confirm your Apt/Ste/Unit number
This setting controls the search prompt for Verification searches which return the Premises partial verification level. You can customise this prompt to assist your users in responding to search results.
USAVerPremisesPartialPrompt=Please confirm sub-premises
This example changes the Premises partial prompt for the USA data mapping to "Please confirm sub-premises".
[identifier]VerStreetPartialPrompt=
Please confirm your building number
This setting controls the search prompt for Verification searches which return the Street partial verification level. You can customise this prompt to assist your users in responding to search results.
USAVerStreetPartialPrompt=Please enter the premises number
This example changes the Street partial prompt for the USA data mapping to "Please enter the premises number".
[identifier]VerMultiplePrompt=
Please choose from the options below
This setting controls the search prompt for Verification searches which return the Multiple matches verification level. You can customise this prompt to assist your users in responding to search results.
USAVerMultiplePrompt=Please select the correct address
This example changes the Multiple matches prompt for the USA data mapping to "Please select the correct address".
