| Status Code | Reason phrase | Description |
| 200 | Success | Request processed successfully. |
| 400 | Bad Request | Request failed due to malformed syntax. |
| 408 | Request Timeout | Response was not returned within the timeout allowance. |
| 500 | Internal Server Error | The server has encountered an error. |
Below is a full list of error codes and their descriptions.
For any other error codes, please contact us.
| Code | Message | Explanation |
| -1000 | qaerr_FATAL | Fatal error |
| -1001 | qaerr_NOMEMORY | Out of memory |
| -1002 | qaerr_INITINSTANCE | Invalid multi-threading instance |
| -1005 | qaerr_INITOOLARGE | INI file too large |
| -1009 | qaerr_FILECHGDETECT | Cannot detect file changes |
| -1006 | qaerr_ININOEXTEND | Cannot extend INI file |
| -1010 | qaerr_FILEOPEN | File not found |
| -1011 | qaerr_FILEEXIST | File already exists |
| -1012 | qaerr_FILEREAD | File read failure |
| -1013 | qaerr_FILEWRITE | File write failure |
| -1014 | qaerr_FILEDELETE | Could not delete file |
| -1015 | qaerr_FILERESV | Reserved device |
| -1016 | qaerr_FILEACCESS | File access denied |
| -1017 | qaerr_FILEVERSION | This occurs if the data files that comprise a dataset have different version numbers. Reinstall your data to ensure that you have the latest versions of all files |
| -1018 | qaerr_FILEHANDLE | Maximum number of files open |
| -1019 | qaerr_FILECREATE | Could not create file |
| -1020 | qaerr_FILERENAME | Could not rename file |
| -1021 | qaerr_FILEEXPIRED | This error occurs if a dataset has expired. Contact Experian Data Quality for a data update |
| -1022 | qaerr_FILENOTDEMO | Can only access demonstration data |
| -1023 | qaerr_FILETIMEGET | Failed to obtain file timestamp |
| -1024 | qaerr_FILETIMESET | Failed to modify file timestamp |
| -1025 | qaerr_READFAIL | Disk read failure |
| -1026 | qaerr_WRITEFAIL | Disk write failure |
| -1027 | qaerr_BADDRIVE | Invalid drive |
| -1028 | qaerr_BADDIR | Invalid directory |
| -1029 | qaerr_DIRCREATE | Could not create directory |
| -1030 | qaerr_BADOPTION | An invalid command line parameter has been used. Enter the correct parameter to continue |
| -1031 | qaerr_BADINIFILE | Could not locate INI file |
| -1032 | qaerr_BADLOGFILE | Could not create log file |
| -1033 | qaerr_BADMEMORY | Invalid memory configuration. Contact Experian Technical Support |
| -1034 | qaerr_BADHOTKEY | Invalid hot key |
| -1035 | qaerr_HOTKEYUSED | Hot key already in use |
| -1036 | qaerr_BADRESOURCE | Could not locate language file |
| -1038 | qaerr_BADTEMPDIR | Bad temporary directory |
| -1040 | qaerr_NOTDEFINED | Entry not defined |
| -1041 | qaerr_DUPLICATE | Entry duplicated |
| -1042 | qaerr_BADACTION | Invalid (list) action |
| -1050 | qaerr_CCFAILURE | Copy control failure |
| -1051 | qaerr_BADCODE | Invalid copy control code |
| -1052 | qaerr_CCACCESS | Copy control access denied |
| -1053 | qaerr_CCNODONGLE | The counter file has not been configured |
| -1054 | qaerr_CCNOUNITS | There are no units left on the appropriate meter |
| -1055 | qaerr_CCNOMETER | No meter can be found for this data |
| -1056 | qaerr_CCNOFEATURE | Feature not supported |
| -1057 | qaerr_CCINVALID | The counter file integrity has failed. Contact Experian Technical Support |
| -1060 | qaerr_CCINSTALL | Copy control not installed |
| -1061 | qaerr_CCEXPIRED | Allowable time expired |
| -1062 | qaerr_CCDATETIME | Date / time is invalid |
| -1063 | qaerr_CCUSERLIMIT | Number of concurrent users exceeded |
| -1064 | qaerr_CCACTIVATE | Copy control installed but not activated |
| -1065 | qaerr_CCBADDRIVE | Invalid copy control drive |
| -1066 | qaerr_CCREGISTER | Product must be registered |
| -1070 | qaerr_UNAUTHORISED | Not authorised |
| -1074 | qaerr_NOLOCALEFILE | Locale file not found |
| -1075 | qaerr_BADLOCALEFILE | Invalid locale file |
| -1076 | qaerr_BADLOCALE | Unknown language / country |
| -1077 | qaerr_BADCODEPAGE | Unknown code page |
| -1078 | qaerr_RESOURCEFAIL | Resource lookup failure |
| -1080 | qaerr_NOTHREAD | Invalid thread handle |
| -1081 | qaerr_NOTLSMEMORY | Out of thread local storage |
| -1090 | qaerr_NOTASK | Could not create task |
| -2300 | qawdperr_BADFUNCTION | Bad function code to library |
| -2301 | qawdperr_NOKERNEL | Kernel must be pre-initialised |
| -2302 | qawdperr_NOPLUGIN | Plug-in not found for this DataPlus set |
| -2305 | qawdperr_ISOPEN | DataPlus file already open by this DataPlus handle |
| -2306 | qawdperr_BADENTRY | Bad DataPlus entry detected (data error) |
| -2307 | qawdperr_NOTOPEN | DataPlus set is not open |
| -2308 | qawdperr_NOCOUNTRY | No country code specified |
| -2309 | qawdperr_PLUGINIT | Problem initialising plug-in |
| -2310 | qawdperr_PLUGBADARG | Bad argument to plug-in - no result returned |
| -2311 | qawdperr_NEWFORMAT | New file format detected |
| -2400 | qallderr_BADFUNCTION | Bad function code |
| -2401 | qallderr_NOKERNEL | Kernel is not initialised |
| -2402 | qallderr_BADHEADER | Bad object header detected |
| -2403 | qallderr_NOOBJSIZE | No object size (internal error) |
| -2404 | qallderr_NOMOREOBJECTS | No more objects (result of attempted move) |
| -2405 | qallderr_BADDICT | Bad dictionary entry detected |
| -2406 | qallderr_BADDATA | Bad compressed data detected in rds |
| -2407 | qallderr_INTDPPROB | More than one DataPlus item returned from lookup |
| -2408 | qallderr_MAXDPLITEMS | Too many DataPlus references |
| -2409 | qallderr_NONAMES | Can't open Names DataPlus set |
| -2410 | qallderr_BEYONDEOF | Offset is beyond end of file |
| -2411 | qallderr_BADOBJCHAIN | Invalid object chain from this object position |
| -2412 | qallderr_BADRANGETYPE | Invalid range type detected |
| -2413 | qallderr_BADRANGESTART | Bad range start value detected |
| -2414 | qallderr_ADSALREADYOPEN | Requested ADS is already open |
| -2415 | qallderr_DELTADELTACOMP | Error decompressing delta-delta index |
| -2416 | qallderr_NOADSFORDTS | DTS reference not found in deltadelta index for this ADS |
| -2417 | qallderr_NOADSFORADS | ADS reference invalid for this ADS |
| -2450 | qacerr_BADFUNCTION | Bad function code |
| -2451 | qacerr_BADCCLASS | Comms class not found |
| -2452 | qacerr_NOLISFUNC | Listen function not specified in listen request |
| -2453 | qacerr_CCNOTIMP | Specified comms class is not yet implemented |
| -2454 | qacerr_ALRDYLIST | Already listening on the specified port |
| -2455 | qacerr_BADTFUNC | Bad transport function called (internal error) |
| -2456 | qacerr_NOLISTENER | Destination is not listening |
| -2457 | qacerr_BADHANDLE | Invalid handle specified |
| -2458 | qacerr_CANCELLED | Connection was cancelled remotely |
| -2459 | qacerr_NOBUFFER | Attempted to take a size of an uninitialised buffer |
| -2460 | qacerr_GETINSCHAR | Get called but there are insufficient characters |
| -2461 | qacerr_NOKERNEL | qacerr_NOKERNEL |
| -2462 | qacerr_NOTXN | Can't call send or receive unless a transaction is in progress |
| -2463 | qacerr_NOTXNNUM | A transaction must have a nonzero transaction number |
| -2464 | qacerr_TERMINATED | Talk was cancelled in the transaction callback |
| -2465 | qacerr_NOREGFUNCTION | No registered function was found for this transaction number |
| -2466 | qacerr_NOTXNMESSAGE | Receive called but no message waiting |
| -2467 | qacerr_NOSERVERMEMORY | No server memory during transaction processing |
| -2468 | qacerr_ATMAXBUFFER | Maximum transaction buffer size reached |
| -2469 | qacerr_NOTLISTENHAND | Comms handle specified is not a listen handle! |
| -2470 | qacerr_SERVERFULL | Maximum server connection count exceeded |
| -2471 | qacerr_DELETESELF | Can't delete own connection |
| -2472 | qacerr_TIMEDOUT | A connection's transaction has timed out |
| -2473 | qacerr_SCANLOCK | Scan already in progress on another instance |
| -2474 | qacerr_VSNNOTSUPPORTED | This version not supported at server |
| -2507 | TCPIP_CONNECTFAIL | The connect attempt failed |
| -2508 | TCPIP_TRANSTHREADFAIL | Transmission thread failure |
| -2511 | TCPIP_INSTANCENOTFOUND | Using invalid connection instance |
| -2514 | TCPIP_TRANSTHREADFULL | Transmission thread message queue full |
| -2517 | TCPIP_LISTENTHREADNOTINIT | The expected listen thread was not found |
| -2519 | TCPIP_INVALIDMSGTYPE | Received invalid message type |
| -2520 | TCPIP_MSGCORRUPTED | Received corrupted message |
| -2521 | TCPIP_MSGQUEUEFULL | Outgoing message queue full |
| -2524 | TCPIP_GETMOREDATA | Retrieving more data |
| -2526 | TCPIP_CANCELLED | Connection cancelled remotely |
| -2549 | TCPIP_LISTENSTRUCT | Failed to create listen data or administrator |
| -2900 | qadcperr_BADFUNCTION | Bad function code |
| -2901 | qadcperr_NOKERNEL | Kernel is not initialised |
| -2902 | qadcperr_NOREGFUNCTION | Function number not recognised by server glue |
| -2903 | qadcperr_CANTCREATEINSTANCE | Can't create server instance |
| -2904 | qadcperr_REINITIALISE | No initialisation instance found for this client |
| -2905 | qadcperr_BADHANDLE | Bad client dataplus handle specified |
| -2906 | qadcperr_SERVERPROBLEM | Error at server |
| -2907 | qadcperr_INVALIDHANDLE | Dataplus handle invalid |
| -2908 | qadcperr_BADCODE | Bad format for dataplus set code |
| -2909 | qadcperr_SETNOTOPEN | Dataplus set is not open |
| -2910 | qadcperr_CLIENTPLUGINERR | Error at client plug-in |
| -3400 | qaerr_INVALIDCOUNTRYINDEX | Invalid index into UIGetCountry |
| -3401 | qaerr_INVALIDLAYOUTINDEX | Invalid index into UIGetLayout |
| -3402 | qaerr_UNKNOWNLAYOUTNAME | Unknown layout name in UISetActiveLayout |
| -3403 | qaerr_UNKNOWNCOUNTRYCODE | UIStartup with unknown ISO code |
| -3404 | qaerr_NOSEARCHENGINESAVAILABLE | Fatal case of the UF reporting no engines available |
| -3405 | qaerr_CANTCHANGEDATABASE | The more common invalid/unknown ISO code error |
| -3406 | qaerr_UIAPIALREADYSTARTED | Multiple calls to UIStartup |
| -3407 | qaerr_UIAPINOTSTARTED | UIStartup not called |
| -3408 | qaerr_UIBADSEARCHSTRING | No longer used |
| -3409 | qaerr_UIBADCDFFORMAT | No longer used |
| -3411 | qaerr_INVALIDLINEINDEX | Invalid index into UIGetLayoutLineElements |
| -3412 | qaerr_NOSELECTEDLAYOUT | No layout in use during call to UIGetLayoutLineElements |
| -3413 | qaerr_NOLIVESERVER | Fatal comms error |
| -3414 | qaerr_BADCONFIGFLAGS | Bad combination of config flags |
| -3415 | qaerr_CANTCHANGEENGINE | Failed to change search engine |
| -3416 | qaerr_NOUFACTIVE | Internal error |
| -3417 | qaerr_UFINVALIDSTATE | Internal sequence error |
| -3418 | qaerr_UILICENSINGERROR | Licensing failure has occurred with one or more data sets |
| -3450 | qaerr_BADFUNCTION | Bad function number |
| -3451 | qaerr_NOKERNEL | No kernel initialised at library call |
| -3452 | qaerr_NOTPRESENT | Shared entity not present |
| -3600 | qaerr_INITFAILURE | QAS TCP/IP failure |
| -3601 | qaerr_CLEANUPFAIL | Sockets failed to clean up properly |
| -3602 | qaerr_ACCEPTFAIL | Error accepting remote connection |
| -3603 | qaerr_SOCKETBIND | Failed to bind socket |
| -3604 | qaerr_LISTENFAIL | Failed to initialise the listen |
| -3605 | qaerr_TALKFAIL | Failed to initialise the talk |
| -3606 | qaerr_SOCKETFAIL | Failed to create socket |
| -3607 | qaerr_CONNECTFAIL | (TCP/IP talk socket) failed to connect to target |
| -3608 | qaerr_ADDRESSERROR | Error looking up remote hostname or address |
| -3609 | qaerr_SENDERROR | Error sending data |
| -3610 | qaerr_RECVERROR | Error receiving data |
| -3611 | qaerr_SELECTERROR | Error during processing of socket select for pending data |
| -3612 | qaerr_TOOLARGE | Message is too large to be transmitted by protocol |
| -3613 | qaerr_PORTINUSE | Specified port number already in use / Non-reusable |
| -3614 | qaerr_CONNECTREFUSED | Could not connect to remote host |
| -3615 | qaerr_CONNECTIONCLOSED | Connection has been lost |
| -3616 | qaerr_SOCKOPTERROR | Error setting socket option |
| -3617 | qaerr_WAITTIMEDOUT | Wait timed out |
| -3618 | qaerr_HOSTNOTFOUND | Host not found |
| -3622 | qaerr_WOULDBLOCK | Socket would block |
| -3623 | qaerr_UNEXPECTED | Unhandled error: please inform Experian QAS Technical Support |
| -3625 | qaerr_WSAEINVAL | Invalid function or argument for socket |
| -3627 | qaerr_NOSOCKETS | (The listen thread has) no sockets attached |
| -3701 | qaerr_CDFSYNTAX | Invalid CDF syntax |
| -3702 | qaerr_BADCDFORDER | Inaccurate item order in CDF |
| -3703 | qaerr_BADCDFITEM | Item in CDF is invalid |
| -3705 | qaerr_INVALIDCDFOBJECT | Invalid CDF object |
| -3706 | qaerr_INVALIDABBREV | Invalid abbreviation |
| -3708 | qaerr_NOSUCHVARIATION | CDF does not have this many variations |
| -3709 | qaerr_OBJECTDEFINITION | Objects incorrectly defined |
| -3710 | qaerr_UNKNOWNOFFSET | Offset supplied was out of range |
| -3711 | qaerr_INVPARSEERR | Push invalid parse has failed |
| -3801 | qaerr_FORMATSYNTAX | Incorrect formatting syntax |
| -3802 | qaerr_TOOMANYADDRLINES | Too many address lines requested |
| -3803 | qaerr_INVALIDADDRESSLINE | Address line out of range |
| -3804 | qaerr_NOFORMATSPEC | No format spec in INI file |
| -3805 | qaerr_FORMATOVERFLOW | Format(s) have overflowed |
| -3806 | qaerr_FORMATTRUNCATED | Format(s) are truncated |
| -3807 | qaerr_BADCDFVERSION | CDF version incompatible with format |
| -3810 | qaerr_PREMISENEEDED | Enter premise details |
| -3811 | qaerr_NEEDRANGEOFFSET | You need to enter number details within a range |
| -4300 | qaerr_UFHANDLING | Engine would like UF to take over |
| -4301 | qaerr_UFNOTHANDLING | UF would like engine to handle again |
| -4302 | qaerr_NOUFGLUEINSTANCE | Glue not initialised |
| -4303 | qaerr_UFNOHK | Housekeeping unavailable |
| -4304 | qaerr_UFNOFUNC | Requested function unavailable |
| -4306 | qaerr_UFCANTSTEP | Can't step in |
| -4307 | qaerr_UFITEMRANGE | Chosen picklist item out of range |
| -4308 | qaerr_UFLAYOUTRANGE | Invalid layout handle given |
| -4309 | qaerr_NOUF | NULL handle given |
| -4310 | qaerr_NOUFSEARCH | No search in progress |
| -4311 | qaerr_ENGINEUNAVAILABLE | Engine cannot be selected |
| -4312 | qaerr_UFCANCELLED | An action has been cancelled |
| -4313 | qaerr_UFNOLAYOUT | No layout matched that supplied |
| -4315 | qaerr_NODATAAVAILABLE | Data unavailable at this level |
| -4316 | qaerr_MOREINEXACT | Data unavailable at this level |
| -4317 | qaerr_CANTSTEPIN | Can't step in |
| -4318 | qaerr_CANTSTEPOUT | Can't step out |
| -4319 | qaerr_BADOPTIONS | Options value(s) wrong |
| -4320 | qaerr_NOENGINESUPPORT | Underlying engine doesn't provide this function |
| -4321 | qaerr_BADSEQUENCE | Functions called out of sequence |
| -4361 | qaerr_CANTFORMATITEM | The informational item cannot be formatted (eg "No matches") |
| -4362 | qaerr_NODATAMAPPINGS | No (valid) datamappings can be found in the QAWSERVE.ini file |
| -4363 | qaerr_MISSINGDATAMAP | The QAWSERVE.ini file contains no datamappings for this request |
| -4552 | qaerr_APIHANDLE | Instance handle invalid |
| -4553 | qaerr_OUTOFSEQUENCE | Function called out of sequence |
| -4554 | qaerr_INSTANCEBUSY | Instance handle already being used |
| -4556 | qaerr_BADINDEX | Index not within valid range |
| -4557 | qaerr_BADVALUE | A value passed was not valid |
| -4558 | qaerr_BADPARAM | Invalid parameter passed to API |
| -4559 | qaerr_PARAMTRUNCATED | API output is truncated |
| -4560 | qaerr_NOENGINE | There is no search engine available for this dataset |
| -4561 | qaerr_BADLAYOUT | The active layout is invalid |
| -4562 | qaerr_BADSTEP | Step-in/Step-out not allowed on item |
| -4570 | qaerr_DATASETNOTAVAILABLE | The dataset cannot be used |
| -4571 | qaerr_LICENSINGFAILURE | Licensing failure has occurred with one or more datasets |
| -4580 | qaerr_SERVERCONNLOST | Lost connection to the server. Transaction timed out or server error |
| -4581 | qaerr_SERVERFULL | The maximum number of server connections has been reached |
| -8300 | qaerr_CTDIFUNC | Unknown client function |
| -8301 | qaerr_CTDINOKERNEL | No kernel instance on client |
| -8304 | qaerr_CTDIBOTTOM | Item is not steppable |
| -8305 | qaerr_CTDISERVERERR | Typedown server error (reported by client) |
| -8400 | qaerr_NOTDGLUEINSTANCE | No Typedown glue instance |
| -8401 | qaerr_TDIFUNC | Unknown server function |
| -8402 | qaerr_TDINOKERNEL | No kernel instance on server |
| -8403 | qaerr_TDINOMATCH | No match |
| -8404 | qaerr_TDIINDEXERROR | Error in typedown index |
| -8405 | qaerr_THRESHOLDTOOLLOW | Threshold was below minimum |
| -8406 | qaerr_TDINOHK | Housekeeping is not initialised |
| -8407 | qaerr_TDINONAMES | Names cannot be opened |
| -8408 | qaerr_TDCANCELLED | Typedown search was cancelled |
| -8409 | qaerr_TDDISCONNECT | Typedown search was disconnected |
| -8410 | qaerr_TDSSWOPFAIL | Typedown swap failed |
| -8411 | qaerr_NORESULTS | Results unexpectedly not present |
| -8412 | qaerr_EMPTYBITMAP | Bitmap was empty |
| -8413 | qaerr_TOOMUCHDATA | Comms exceeded |
| -8500 | qaerr_HOUSEFUNC | Bad function code |
| -8501 | qaerr_HOUSENOKERNEL | Kernel is not initialised |
| -8502 | qaerr_REMOTEINLOCK | Remote INI file is locked |
| -8650 | qaerr_ZLCFUNC | Function unavailable |
| -8651 | qaerr_ZLCNOKERNEL | Kernel not initialised |
| -8652 | qaerr_ZLCDISTANCE | Maximum search range cannot be less than minimum |
| -8653 | qaerr_ZLCBADTERM | Search term must contain at least one letter or number |
| -8654 | qaerr_ZLCNOMEMORY | Client out of memory |
| -8655 | qaerr_ZLCTOOMANYMATCHES | Too many matches found |
| -8660 | qaerr_ZLCABORT | Search cancelled |
| -8661 | qaerr_ZLCTIMEOUT | Search timed out |
| -8750 | qaerr_ZLSFUNC | Unknown function |
| -8751 | qaerr_ZLSNOKERNEL | Kernel not initialised |
| -8752 | qaerr_ZLSABORT | Search aborted |
| -8753 | qaerr_ZLSTOOMANYMATCHES | Too many matches found |
| -8754 | qaerr_ZLSTIMEOUT | Search timed out |
| -11500 | qaerr_LICFILENOTFOUND | Licence File not found |
| -11501 | qaerr_INVALIDLICENCEKEY | Invalid license key |
| -11502 | qaerr_LICENCECONFLICT | Conflicting licenses found in license file |
| -11510 | qaerr_LICENCENOTFOUND | Licence not found |
| -11511 | qaerr_LICENCEEXPIRED | Licence expired |
| -11512 | qaerr_EVALUATIONEXPIRED | Evaluation license expired |
| -11520 | qaerr_BADINPUTPARAM | Invalid input parameter |
| -11521 | qaerr_INVALIDDATE | Invalid date |
| -11523 | qaerr_NONEXPIRYMETERTRANSFER | Transfer of non-expiry GBR clicks not allowed |
When SOAP errors are returned, they are passed to the user via the XML interface in the form of a fault message. Fault messages are customized to provide error information that does not include any confidential details about the application.
| -4600 | qaerr_XMLPARSEFAILURE Failure to parse XML. Returned if the SOAP action sent to the server does not conform to the WSDL file: commonly occurs if attributes and/or elements do not contain valid settings. The integration environment may not validate the SOAP action against the WSDL file, and so it is possible to pass values that are outside defined ranges or thresholds. | |
| -4650 | qaerr_SOAPHTTPPARSEFAILURE Failed to parse HTTP request. | |
| -4651 | qaerr_SOAPENVELOPEPARSEFAILURE Failed to parse SOAP envelope in request. | |
| -4652 | qaerr_SOAPENVELOPENOTPRESENT No envelope found in parsed XML. | |
| -4653 | qaerr_SOAPNAMESPACEMISMATCH SOAP namespace does not match. | |
| -4654 | qaerr_SOAPBODYNOTPRESENT No body could be found. | |
| -4655 | qaerr_SOAPREQUESTPARSEFAILURE Payload of message could not be parsed. | |
| -4660 | qaerr_XMLINVALIDACTION Invalid SOAP action. |
