Mapping allows you to map a collection of data values returned by the Experian Email Validation API to a collection of Microsoft Dataverse entity fields / table columns.
The pre-configured mappings that come with the solution (Address1 and Address2) are designed just for addresses out of the box but can optionally be utilized for mapping email data too, assuming the additional email data has been enabled and the fields created as detailed in the previous sections of this guide.
Configuring an email mapping
First select an existing mapping or add a new one:
- Go to the Experian Data Validation Configuration Power App.
- Select the Map fields page from the left menu.
- From the entities (tables) list on the left, select the entity (table), for which you want to configure an email mapping.
- Either select an existing mapping from the list in the MAPPINGS column or click + Add in the top menu to create a new mapping.
- If adding a new mapping, select the Entity (Table) name, provide a Mapping name and specify the Validation types it will use. If the mapping will only be used for email fields, you need only select Email as the type and click Add.
Validation types
Restricting the mapping to certain validation types simplifies the mapping interface, but note that it can't be changed once the mapping has been created. You would need to delete the mapping and create a new one.
The properties from our Email Validation API are found under the Email tab, with optional email validation status and timestamp fields in the ADDITIONAL grouping, plus RESULT and METADATA groupings which only appear if properties are enabled on the Additional data page under the Email result or Email metadata sections.
The process for mapping the fields is as follows:
- Under each API property is a combo box that contains the fields of the associated entity (table). Click on each combo box and select the field that you want populated with that API value. The list is separated into five types for convenience, depending on the data type of the field:
- Text - the text value returned by the API is stored in the field.
- Number - the integer or decimal value returned by the API is stored in the field. If the entity field / table column only holds integers and a decimal value is returned by the API, the value will be truncated to an integer value.
- DateTime - the date and time value returned by the API is stored in the field.
- Choice - the item selected for the choice field will be the one where the text of the choice item matches the text returned by the API using a case insensitive match.
- Lookup - the lookup record selected for the field will be the one where the text of the primary name column of the Lookup table matches the text returned by the API using a case insensitive match.
- Optionally, if you want to save the validation message and timestamp, select the fields created previously from the combo boxes for the Email validation message and Email validation timestamp API properties. See Validation tracking fields if you have not yet created these special fields.
- For any email fields that you want to ignore, choose the value Not mapped from the combo box.
Choice and Lookup fields
If you map to a Choice or Lookup field without additional configuration, an empty value will be saved to the mapped field if a match is not found amongst the Choice or Lookup values.
Be careful when populated fields are unmapped
If a form field mapped in an email mapping has been used to populate an entity record / table row and is subsequently unmapped from the mapping, the field values for the records that have already been populated will need to be cleared. Otherwise, there is the possibility that the value in the field is associated with an email address returned from a subsequent email validation.
If you have configured a mapping for additional email data as detailed above you will need to associate the mapping with the email field on the form.
- Select Tables from the left hand menu of the main Power Apps interface.
- Click the Table you want to configure.
- Click Forms from the Data experiences panel at the top of table page.
- Click the Form you want to configure (e.g. Account).
- Select the email field you would like to configure.
- Select the Properties tab in the panel on the right, scroll down to and expand the Components section.
- Click the three dots icon next beside EDQEmail and click Edit.
- Under Mapping name enter the name in the Static value text box. This would be Address1 or Address2 if you're using the mappings that come pre-configured with the solution. Otherwise enter the new mapping name you created above.
Once all the steps have been completed click Done to close the component configuration panel and repeat for other email fields as required. Finally, click Save and publish in the command bar to commit your form changes.
Testing an email mapping
- Make sure all the fields that were mapped have been added to the form for the relevant entity/table.
- View a record for the entity/table you want to test and try to validate an email address using an EDQ component.
- If the validation is successful, check that the mapped fields are populated with the data you were expecting.
Mapped field must be present on the form
If a mapped field is not present on the form when the page loads an error will be displayed in the browser console to help you diagnose and fix the issue, for example:
