Adding fields to a form
Having created all the new fields you require in the previous section you now need to add them to your forms.
  1. Select Tables from the left hand menu of the main Power Apps interface.
  2. Click the Table you want to configure.
  3. Click Forms from the Data experiences panel at the top of table page.
  4. Click the Form you want to configure (e.g. Account).
  5. Drag and drop the field from the Table columns panel on the left-hand side into the location you want on the form. To make things easier use the filter at the top to show only Custom fields.
  6. Repeat this step for all the fields required.
  7. Click Save and publish in the command bar to commit your form changes.
Field configuration complete
With all your new fields created and added to your forms you're now ready to move on to the next section where you will map the fields.
