Configuration import/export
Should you wish to store a backup of your app configuration, we offer the ability to export and import your configuration.
The exported file contains the following configuration details:
  • Product configuration, including authentication token, address datasets, timeout, output format, etc.
  • Additional data selections
  • Mapped fields
  • Advanced API value mappings, set up using Text, OptionSet or Lookup maps
  • Customizations to the Choices shipped with the solution - edq_country, edq_dataset and edq_countryphonecodes
Import configuration
  2. Select the Import and export page from the left menu.
  3. Click the Import configuration tab.
  4. Click Choose file and select a previously exported configuration file.
  5. The file is uploaded and validated. The solution dependencies that will be restored are shown and the Import button will become active.
  6. Click Import and observe the status as all the actions are carried out.
  7. Confirmation of successful import will be displayed and you can then click Finish.
Export configuration
  3. Click the Export configuration tab.
  4. The configuration details will be loaded and displayed on the page.
  5. Click the Export button.
  6. A JSON file containing the current configuration is generated and downloaded.
Delete dependencies
If you intend to export your configuration and delete the solution afterwards, we offer the ability to automatically remove all solution dependencies, with the exception of those related to Power Pages websites. These are handled separately.
  3. Click the Delete dependencies tab and wait for the solution dependencies to be loaded and displayed on the page.
  4. Check the I have exported the solution configuration box to confirm you have exported your configuration.
    Delete dependencies
  5. Click Delete dependencies and observe the status as all the actions are carried out.
  6. Optionally click the Save Report button if you want to keep a record of the actions performed.
Accessing the import/export UI via a URL
We offer an alternative way of accessing the configuration import/export feature if you are unable to access the configuration app. A very minimal version of the user interface can be accessed directly via the following URL:
https://<environment-name>.crm<n>.dynamics.com/WebResources/edq_import_export_ui
  • <environment-name> is the name of your Power Platform environment.
  • <n> is a region-specific number which is sometimes present (e.g. crm8 for UK South).
Import/Export UI via direct URL
Microsoft Dynamics 365 and Power Platform
Additional features
  • Configuration import/export
