Select the dataset attributes returned by the Experian Enrichment API that you would like to map to fields on your forms:
  2. Select the Additional data page from the left menu.
  3. Select Address enrichment from the ADDITIONAL DATA column.
  4. Select the dataset you are interested in from the DATASET column
  5. Select the attributes from the ATTRIBUTE column that you would like to be enabled for mapping. Once an attribute has been selected the dataset and group will both be marked with a tick icon to indicate they contain an enabled attribute.
  6. Repeat these steps for other attributes as required and then click Save to save your choices.
  7. They will now appear on the Map fields page under Address data fields within the ENRICHMENT panel.
Selecting enrichment data
