Select the individual address components returned by the Experian Address Validation API that you would like to map to fields on your forms:
  2. Select the Additional data page from the left menu.
  3. Select Address components from the ADDITIONAL DATA column.
  4. Select the address component group you are interested in from the COMPONENT GROUP column.
  5. Select the components from the COMPONENT column that you would like to be enabled for mapping. Once a component has been selected the dataset and group will both be marked with a tick icon to indicate they contain an enabled component.
  6. Repeat these steps for other address components as required and then click Save to save your choices.
  7. They will now appear on the Map fields page under Additional data fields within the COMPONENTS panel.
Selecting address components
