Select the Experian Address Validation and Enrichment gecoding components that you want to appear in any validation you do.
Address Validation components
  1. Get to the Configuration page.
  2. Click the Select components tab.
  3. Click Address in the left column.
  4. Click each Component group in the middle column and select each Component in the right column you want to retrieve at validation and can be mapped.
    After selecting the components you want, they will appear in the Map fields tab, under Additional Components.
Enrichment components
Dataset Integration setup
Global dataset Select Activate Enrichment. The global dataset will automatically be included with any search.
Regional dataset Select Activate Enrichment. You need to add your regional datasets. If you do not you will get a 401 error.
Global dataset and Regional dataset Select Activate Enrichment. The global dataset will automatically be included with any search. For the search to use your regional datasets, you will need to add them to the select components tab.
