Mapping management
The following management options are available from the Map fields page of the Experian Data Validation Configuration Power App.
Deactivating a mapping
If you wish to deactivate a mapping, select it and click Deactivate in the top menu. It will then be shown with a strikethrough.
Mapping deactivated
If you have several deactivated mappings you can click View active only in the top menu to hide them. This can be reversed by clicking View all.
Reactivating a mapping
If you wish to reactivate a mapping, select it and click Reactivate in the top menu.
Deleting a mapping
A mapping can only be deleted if it is deactivated. Once deactivated, select the mapping and click Delete in the top menu. Click OK to confirm.
