Layout Manager
The Layout Manager is used to specify layouts for each address dataset. Pro Web uses a layout to determine:
  • The format that addresses will be returned in.
  • Any elements that you want to be automatically formatted into addresses or excluded from results, such as PNRL localities.
To view the Layout Manager, click Layout Manager on the toolbar. Alternatively, you can select Layout Manager from the View menu.
The Layout Manager appears, listing your datasets and the layouts available for each. From here you can view and alter the existing layouts, or create new layouts. Click on a dataset to display the Dataset Properties pane, which shows summary information about the dataset. Click on a layout to display the Layout Properties pane, which shows summary information about the layout.
Each installed dataset has a default layout associated with it. You can modify this layout, but Experian recommend that you leave it as it is and create a new layout if you want different settings. You will want to create more than one layout for each dataset if you intend to paste addresses into multiple applications which require different address formats.
Creating a new layout
To create a new layout, follow these steps:
  1. Expand the Layout Manager in the outline control and click on the dataset for which you want to create a new layout.
  2. From the Layout menu, select the New option. Alternatively, click the secondary mouse button on the data mapping, and select New from the menu.
  3. If you are creating a new layout for a USA data mapping and you have USA DPV data, DPV footnote DataPlus elements will automatically be added to your new layout to enable DPV.
  4. For datasets which include more than one Form of address, such as the Netherlands, Belgium and Finland datasets, you must choose the Form of address before the new layout is created. For more information about Forms of address, see the Data Guide for your dataset.
  5. Your new layout appears with an automatically generated name in an editable text box. Edit the name and press Enter. You can include any alphanumeric character, and the space character in the names of layouts.
  6. In the Layout Properties pane on the right, under Comment you can enter a short text description of the layout for your own reference. The larger Summary box at the bottom of the pane provides a summary of all the settings in the layout. Initially these correspond to those of the standard layout (for the current dataset) which was copied to create the new layout.
The new layout will have the same settings as this dataset's default layout.
Formatting the returned address
Now that you have created a new layout, you can specify exactly how you want your addresses to look using the Address Format pane. To view this pane, expand your new layout (by clicking on the plus sign next to the layout name), and select Address format from the list that appears.
The Address Format settings will initially be the same as the default layout. The pane will contain the address elements for the dataset you chose for your layout. From here, you can use the functions on the pane to fully customize the address elements you want your layout to return. For more information see the Configuration Editor Help program.
Configuring DataPlus lines
If you have one or more DataPlus sets, you must specify the format of the returned information by clicking on DataPlus in the list under your layout name. This window is structured in a similar way to the Address Format window. For more information see the Configuration Editor Help program.
Saving your layout
Click the Save button on the toolbar at any time to save the changes you have made to your layout. Alternatively, press CTRL+S, or click Save on the File menu.
