Country and Dataset option sets
You can customise the countries and datasets that are visible on your form drop down. The solution comes installed with all the available options. You can however delete the ones you no longer need.
Delete Country option set
  1. Go to Customize the system.
  2. Click on Option Sets.
  3. Double click the Country display name (Name: edq_country).
  4. In the Options box, select the Country you want to delete.
  5. Click the Delete button at the top of the Option box.
  6. Click Save an Close.
Delete Dataset option set
  3. Double click the Dataset display name (Name: edq_dataset).
  4. Record and save the Label (case sensitive), you will need this if you want to add this Dataset back later.
Add the Option set back in
  3. Double click the Country display name (Name: edq_country) or the Dataset display name (Name: edq_dataset).
  4. Click the Add button at the top of the Options box.
  5. enter the Label (For Datasets it is case sensitive, please enter exactly as it was previously).
  6. Enter a description - For country, add in the 3 digit ISO code in the description. For Datasets add the Dataset name.
  7. Click Save an Close.
Adding a new Country Option set
  5. enter the Country in the Label field.
  6. Enter the 3 digit ISO code in the description field.
