Postal address clean report
The reports available to you depend on your chosen settings and whether you are Cleaning postal or email addresses.
All Countries
Overall Summary Report
A more detailed version of the information found in the Results Summary pane of the Results screen, including a statistical breakdown of the Job's results.
If you are cleaning French addresses, this will be called 'French Clean Summary Report', as French Match Profiles will be used.
Australia
Your Job must be configured to use the AMAS Certified (Postal Address File) layout to qualify for this report.
AMAS Certification Report
The Address Matching Approval System (AMAS) Certification Report an be used to qualify for reduced postage rates from Australia Post. Read more.
Canada
Your Job must be configured to use the Canada layout to qualify for this report.
SERP Certification Report
The Software Evaluation and Recognition Program (SERP) Certification Report can be used to qualify for reduced postage rates from Canada Post.
New Zealand
Your Job must be configured to use the New Zealand layout to qualify for these reports.
New Zealand Statement of Accuracy Report
The Statement of Accuracy (SOA) Report can be used to qualify for reduced postage rates from New Zealand Post.
New Zealand Log Report
The New Zealand Log Report maintains a running record of the Statement of Accuracy reports that you produce over time. Include this report to see a record of your current and previous SOAs.
United States
Your Job must be configured to use one of the United States layouts to qualify for this report.
CASS Certification Report
The Coding Accuracy Support System (CASS) Certification Report can be used to qualify for reduced postage rates from USPS.
