Match codes
Match codes describe the differences between input postal addresses and their corresponding cleaned addresses. They can be used to achieve an in-depth analysis of the changes that have been applied. They can also be used to programmatically select addresses to be added back into your database.
If you have processed postal address data, Match Codes are always included as the first field of each address in your Cleaned Address File. See an example of what this looks like.
An example match code is broken into its component sections below.
The Match Success Indicator is always one upper case letter and describes how well the input address matched to the output address returned by Clean.
Letters A-D mean that the address was not processed. The reason for this is indicated by the letter returned.
Match Success Indicator Description Explanation
A Unprocessed Results could not be returned for the input address. This reflects an internal processing issue, and should not occur during normal usage.
B Blank This means that Clean could either find no data in the input address or too insignificant an amount of data to return an address.
C Country not available This match letter is returned when your input address contains the name of an unsupported country.
D Unidentified Country A match letter of D is assigned to the address record when Clean is unable to ascertain the country of origin.
Letters K-R mean that the address was successfully processed. The quality of the match is indicated by the letter returned.
K No address or postcode could be derived This match letter is used when Clean cannot find any data which matches your input address. For example, if you processed 42 Durlston Square, Clean would return a K match. This is because there are no matching street names within the United Kingdom, and Clean has no other information (such as a locality or postcode) to search on.
L Postcode found, but no address could be derived This match letter is returned if Clean derives a valid postcode from your input address information but did not find a matching address
M Multiple addresses found, but no postcode Clean returns this match letter if the input address matches more than one address in the dataset. For example, the address below returns four matches:
146 High Street, Cambridge
As the address exists in the localities of Sawston, Cottenham, Chesterton and Landbeach, Clean cannot determine what is the desired match. As all four potential matches have different postcodes and no single postcode can be returned, Clean marks the address as an M match.
N Multiple addresses found with postcode This type of match is returned when Clean finds more than one matching address within a postcode.
O Partial address found, but no postcode In this case Clean has found a partial address which matched your input. However, it cannot return a full postcode with it, because the partial address is covered by more than one postcode. This might occur if your input address has a missing or invalid property number. Clean cannot determine the correct property number, and returns as much of the address as it can. For example, in this address, number 70 does not exist:
70 Glebe Road, Long Ashton, Bristol
As no postcode is included in the input address, Clean does not know which of two possible postcodes to return, and produces this output:
P Partial address found with postcode Clean has found a partial address which matches your input. In addition, either the input postcode was valid, or Clean has managed to find a single postcode for the partial address. For example, if this address is searched on:
Tooting Bec Rd, London
Clean is able to add a postcode and state code, but the lack of property number prevents the return of a full address.
Q Full address found, but no postcode This occurs when Clean finds a full address which matches your input data, but cannot find a full postcode to go with it.
R Full address and postcode found In this case, Clean has made a full match, either by simply verifying a correct input address, or by locating a full address from the partial input data. The following example returns an R match:
14 Carnaby St, London
However, an R match only signifies that a full address and postcode have been returned; it does not necessarily mean that the address is the one you want. You can gauge the likelihood of a correct match from the match confidence level.
The Confidence Level is always one single digit and indicates the level of confidence which Clean has in each match. There are three possible values:
Confidence Level Description Explanation
9 High confidence Indicates that the output address matches the input address.
5 Intermediate confidence Indicates that the less important rules were not satisfied, such as:
  • There must be some form of match with a street name.
  • If none of the place elements have been matched, the postcode must be matched.
0 Low confidence Indicates that the essential matching rules were not satisfied. These rules include such conditions as:
  • There must be an input element defining the location of the address (a town, a postcode etc).
  • There must be an element defining property information.
Postal Code Action indicates any action that Clean has performed on the postcode. There are four possible values:
Postal Code Action Explanation
0 No action was taken (usually because no postcode was found, or the address was not processed).
1 The existing postcode was already correct.
2 A postcode has been added.
3 The existing postcode has been corrected.
Address Action indicates any action that Clean has performed on the address, other than the postcode. There are three possible values:
Address Action Explanation
0 No action was taken (usually because the input address could not be matched to a correct address).
2 The existing address was enhanced. No significant information has been removed, but some information has been added.
3 A partial or complete address was returned. The amount of address is signified by the match success indicator.
Generic Information Bits are used to communicate general changes to your address information.
Information Bits are added together to make up a hexadecimal code. The example above is a combination of 00002000 (change of key premises number) and 00000020 (non-trivial cleaning).
Information Bit Description
10000000 The elements in the input address were not in the expected order. For example, the address "7 Old Town, SW4 0JT, London", would be changed to place the postcode at the end of the address.
20000000 Preferred matching rules were not satisfied, and the match will be, at best, intermediate confidence.
40000000 The address has been marked with, at best, intermediate confidence because close matching rules have been satisfied.
80000000 Conditional formatting has taken place. Some address elements in the specified output format were not present in the matched address record and have been replaced with equivalent address elements.
01000000 Extra numbers were found in the address. An example might be "Flat 2, 12 10, Abbeville Road, London".
A full match was achieved, (Flat 2, 10 Abbeville Road, London, SW4 9NJ) but the additional number(s) (i.e. "12" in the above example) may reduce the confidence level to Intermediate.
02000000 Additional text between a number and its expected adjacent component has been found, for example between a property number and a street name. The confidence level has been reduced to Intermediate.
04000000 No place element was found in the address, so the confidence level may be reduced.
08000000 An item associated with a number is missing. For example, in the address "4, South Marston, Swindon, SN3 4XX" should include the street name "Ash Gardens" after the building number.
00100000 One or more essential matching rules were not satisfied, so the confidence level has been reduced to low.
00200000 A timeout has occurred and the address has not been matched. This error should occur extremely rarely; if you encounter this problem, please let us know.
00400000 The input address was a superset of the address found by Clean.
For example, the input address "Village Arcade, 5 Hillcrest Road, Pennant Hill, NSW, 2120" contains more information than the official version, which does not contain the "Village Arcade" element.
00800000 The input address contained leading information which was not matched in the return address.
For example, the input address "8 Piermark Drive, PO Box 1116, London, SE1 7AG" contains more information than the official version, which does not contain the "8 Piermark Drive" element.
00010000 There was ambiguity in the supplied range in the input address.
For example, the address "138-140 Tooting Bec Road, London" has an ambiguous range because there are premises numbered 138, 139 and 140 on Tooting Bec Road and the input address cannot be matched to a specific property.
00020000 A street descriptor has been added or has changed. For example, given "4 Oamaru Street, Devizes", the correct descriptor "Way", is returned instead of "Street".
00040000 Additional text in the input address was too significant to ignore. This returns intermediate confidence.
00080000 There was an error in the input street name that Clean has amended.
00001000 There was an error in an input place name. This has been corrected by Clean.
00002000 Clean has added or changed a key premises number or range compared with the input address.
00004000 An exact street level match cannot be made, and there is more than one possibility of matching by changing either the street or the place. Due to this ambiguity at the street level, Clean cannot safely match the input address.
00008000 A name was used to secure an address match.
00000100 The address line settings of the currently configured layout are of an insufficient width to contain each address element. Widen the address lines to ensure that the address elements are not truncated.
00000200 Complete address element(s) are unable to fit on the address line. Widen the address lines to ensure that all of the address elements are visible.
00000400 Clean failed to generate one or more non-address items. Address matching is unaffected.
00000800 When in enhanced cleaning mode, Clean cannot fill the unmatched address elements back into the database. To resolve this, widen the address lines or add additional lines.
00000010 Address elements have been moved to the right or downwards to allow unmatched elements to be incorporated, to produce an enhanced address.
00000020 Clean has determined that the supplied address has been non-trivially cleaned. This means that spelling may have been corrected, capitalisation changed, or the input address elements could have been reformatted in some way. Note that quotes and spaces are ignored during Clean's comparison process.
00000040 Key input address elements were judged effectively correct as supplied, although note that the output address's representation or formatting may differ (for example, address elements may have been expanded or abbreviated, or capitalisation changes may have been made).
00000080 The amount of input lines specified during configuration does not match the number of lines found in the input file. This Information Bit does not affect the confidence level.
00000001 An unambiguous match has been found, but stricter checks have resulted in the confidence level being reduced to, at best, intermediate.
00000002 Clean has found a premises level partial address match.
00000004 Clean has found a street level partial address match.
00000008 Clean has found a place level partial address match.
Country Information Bits are used to communicate detailed changes to your address information.
Country Information Bits are added together to make up a hexadecimal code. The example above (which relates to USA data) is a combination of 1000000 (ZIP+4 has been assigned) and 08000000 (Address converted using LACS).
Extended Country Information Bits are used to communicate detailed changes to your address information. They are not available for all countries.
Information Bits are added together to make up a hexadecimal code. The example above (which relates to USA data) is a combination of 0020000 (address was DPV confirmed) and 00004000 (business address improved using SuiteLink data).
A Country identifier is appended to all match codes, and indicates the country which Clean cleaned (or attempted to clean) the address against.
10000000 An exact street level match is not possible as more than one non-exact match is possible by changing either a supplied street element or the supplied locality. If this information bit is set, no match is returned.
20000000 Multiple street type(s) or invalid street type(s) are supplied in the input address, and there is more than one match with the equivalent match quality. If this information bit is set, match confidence is reduced.
40000000 Multiple PO Box types were supplied in the input address, or the changes required to obtain a match makes the input postal delivery type invalid. If this information bit is set, match confidence is reduced.
80000000 A bordering locality match is prohibited because a match is already available in the locality that was entered, and can be returned by changing the street type or street type suffix
01000000 No additional valid secondary information has been supplied in the input address given a real or phantom primary point reference address match.
02000000 A match has been made to a real primary point, a holding premises which is a valid delivery point in itself.
04000000 A match has been made to a phantom primary point. These are holding premises which cannot be a valid delivery point without valid additional secondary information.If the address is cleaned in the AMAS certified mode, match confidence will be reduced to intermediate if information bit 01000000 is also set.
00100000 The supplied Customer Barcode Info field is blank.
00200000 Invalid characters are present in the supplied Customer Barcode Info field. The valid characters are letters, numbers, spaces and hashes.
00400000 The 52 digit extended barcode (AUSBAR.Ext52) can convert a maximum of 5 Customer Barcode Info characters. If your Customer Barcode Info contains more than 5 characters, this information bit is returned and the field is treated as blank when generating the barcode.
00800000 The 67 digit extended barcode (AUSBAR.Ext67) can convert a maximum of 10 Customer Barcode Info characters. If your Customer Barcode Info contains more than 10 characters, this information bit is returned and the field is treated as blank when generating the barcode.
00010000 The building number has been amended. For example, a single number in the input address has been matched to a range containing that number.
00020000 There was an error in the building name.
00040000 Floor/Level information has been added or amended.
00080000 Flat/Unit information has been added or amended.
00001000 There was an error in the street name.
00002000 The street type has been added or changed.
00004000 The street type suffix has been added or changed.
00008000 A street alternate form has been matched and may be retained in the output address (where the 'Street alias' output item has been fixed during configuration).
00000100 There was an error in the locality information supplied in the input address.
00000200 There was an error in the state information supplied in the input address.
00000400 The flat/unit number or the sub-premise number that was entered did match that in the data, but the type/descriptor did not match. In this case, the type or descriptor entered by the user will be retained in the output address.
00000800 A valid bordering locality and postcode combination has been matched.
00000010 Street level (DID) address matched.
00000020 Locality level (DID) address matched.
10000000 A street alias has been matched and may be retained in the output address if the street alias output item has been fixed during configuration.
20000000 A locality alias has been matched and may be retained in the output address if the locality alias output item has been fixed during configuration.
40000000 A bordering locality has been matched and may be retained in the output address.
01000000 A match has been made to premises-level, specifically building number, only. No sub-premises item has been matched.
02000000 No additional valid secondary information has been supplied in the input address. A building number has been supplied and matched.
04000000 A building number and valid secondary information have been supplied in the input address but neither matched. The unmatched secondary information may be retained in the output address.
00100000 A valid PO Box type has been supplied in the input address.
10000000 Premises number optimized, changed or inserted.
20000000 Route number optimized, changed or inserted.
40000000 Extraneous data optimized, changed, inserted or removed.
80000000 Street suffix optimized, changed, inserted or removed.
01000000 Station name optimized, changed, inserted or removed.
02000000 Station type optimized, changed, inserted or removed.
04000000 Station qualifier optimized, changed, inserted or removed.
08000000 Province optimized, changed, inserted or removed.
00100000 Street type optimized, changed, inserted or removed.
00200000 Street direction optimized, changed, inserted or removed.
00400000 Community optimized, changed, inserted or removed.
00800000 Street name optimized, changed, inserted or removed.
00010000 Apartment keyword optimized, changed, inserted or removed.
00020000 Route/Box keyword optimized, changed, inserted or removed.
00040000 Foreign record keyword optimized, changed, inserted or removed.
00080000 Apartment number optimized, changed, inserted or removed.
00001000 Box number optimized, changed, inserted or removed.
00002000 Street number outside valid range.
00004000 Route Number outside valid range.
00008000 Invalid '#' symbol in address.
00000100 Valid Postal CodeOM.
00000200 Postal CodeOM changed from Rural to Urban.
00000400 Postal CodeOM corrected.
00000800 Local Delivery Unit (LDU) changed.
00000010 Forward Sortation Area (FSA) changed.
00000020 Postal CodeOM inserted.
00000040 Postal CodeOM changed.
00000080 A better Postal CodeOM exists.
00000001 Address considered Valid for SERP (no changes required to input).
00000002 Address considered Correctable for SERP (input has been corrected and a unique match supplied).
00000004 Address considered Non-Correctable for SERP (input could not be corrected or is too ambiguous to supply a unique match).
10000000 The address was deemed to be correct as supplied. All address elements were supplied on the correct lines and in the correct format.
20000000 The address was matched with a high degree of confidence, but some corrections were made. For example, spelling or formatting may have been corrected, or missing address elements may have been added.
40000000 A match was found, but Clean cannot be certain that the returned address is the correct one. For example, the returned address may be very different from the input, important address elements may have been changed, or other equally good matches may exist in the data. The match has been downgraded to intermediate confidence, and the user should check the returned address manually.
80000000 As well as the returned address, Clean found one or more alternative addresses of similar quality. For example, the supplied street does not exist but there are two very similar streets to choose from. When this situation arises, the information bit 4000000 is also set.
01000000 The returned address is in a format that conforms to the AFNOR standard. This specifies which address line should be used for each address element, the maximum length of each line, and the abbreviations that should be used.
00001000 A secondary street name was supplied but was not matched in the data. This has been returned as part of the address.
00000100 A premises number was supplied for the secondary street but was not matched in the data. This has been returned as part of the address.
00000200 A premises suffix was supplied for the secondary street but was not matched in the data. This has been returned as part of the address.
00000010 A primary street name was supplied but was not matched in the data. This has been returned as part of the address.
00000020 A locality name was supplied but was not matched in the data. This has been returned as part of the address.
00000040 A PO Box number was supplied for the primary street but was not matched in the data. This has been returned as part of the address.
00000080 An organisation name was supplied for the primary street but was not matched in the data. This has been returned as part of the address.
00000001 A premises number was supplied for the primary street but was not matched in the data. This has been returned as part of the address.
00000002 A premises suffix was supplied for the primary street but was not matched in the data. This has been returned as part of the address.
10000000 English Primary Locality added that was not supplied in the input address
20000000 Gaelic Primary Locality added that was not supplied in the input address
40000000 English Secondary Locality added that was not supplied in the input address
80000000 Gaelic Secondary Locality added that was not supplied in the input address
01000000 Street retained from the input address that is not in the data
02000000 Street added that was not supplied in the input address
00100000 Match to bordering locality
00200000 Match to bordering Dublin district number
00400000 Wrong Dublin district number supplied
00800000 Match to bordering county
00020000 Posttown added
00001000 Gaelic Primary Thoroughfare available
00002000 Gaelic Secondary Thoroughfare available
00004000 Gaelic Primary Locality available
00008000 Gaelic Secondary Locality available
00000100 English Posttown has been removed
00000200 Gaelic Posttown has been removed
00000400 English Resident Preferred Posttown has been removed
00000800 Gaelic Resident Preferred Posttown has been removed
00000010 Non-trivial change applied as a result of referencing An Post data
10000000 Unique match - matches to a unique delivery address.
20000000 Base Address match - matches to a street number.
40000000 Invalid match - does not match to a delivery address.
01000000 Sub-premise information added.
02000000 Street Type difference in matched address.
04000000 Street Name difference in matched address.
08000000 Street Direction difference in matched address.
00200000 Rural delivery difference in matched address.
00400000 An invalid match caused by matching a suburb alias. This bit will only be set if other elements were valid.Records with this information bit will be excluded from the SOA report, if you requested one.
00800000 Rural address match with missing or unmatched premise info.Records with this information bit will be excluded from the SOA report, if you requested one.
00010000 This bit will be set for Poste Restante addresses.Records with this information bit will be excluded from the SOA report, if you requested one.
00020000 This bit will be set for Private Bag addresses.Records with this information bit will be excluded from the SOA report, if you requested one.
00040000 Lobby added or corrected in matched address.
00080000 Suburb added or corrected in matched address.
00001000 City added or corrected in matched address.
00002000 A valid suburb alias has been matched and may be retained in the output address if the suburb alias output item has been fixed during configuration.
00004000 A valid city alias has been matched and may be retained in the outputp address if the city alias output item has been fixed during configuration.
00000100 Unambiguous match to an address with 'deleted' status with no alterations to any of the PAF address elements.
10000000 Floor/unit numbers were supplied, but not matched in the data. The supplied floor/unit numbers have been returned as part of the address.
20000000 Additional unit information was supplied, but is not available in the dataset. The supplied additional unit information has been returned as part of the address.
10000000 Postcode has been recoded.
20000000 Multiple recodes exist for supplied postcode.
01000000 Town added or altered.
02000000 County added or altered.
04000000 PNR county form present for matched address.
00100000 Dependent locality added or altered.
00200000 Double dependent locality added or altered.
00400000 Postally non-required locality alias is retainable in the output address.
00010000 Thoroughfare name difference.
00020000 Thoroughfare descriptor added or changed.
00040000 Dependent thoroughfare name difference.
00080000 Dependent thoroughfare descriptor added or changed.
00001000 Building number corrected (for example, a single premises number corrected to a range).
00002000 Building name amended.
00004000 Sub-building number corrected (for example, a single premises number corrected to a range).
00008000 Sub-building name amended.
00000100 Organisation name altered.
00000200 Organisation name matched to reference initials.
00000400 Organisation department name added or changed.
10000000 ZIP+4 has been assigned.
20000000 DPBC has been assigned.
40000000 5-digit ZIP has been assigned.
80000000 Address is a High Rise Default.
01000000 Address is a High Rise Exact.
02000000 Address is a Rural Route Default.
04000000 Address is a Rural Route Exact.
08000000 Address converted using LACS.
00100000 USPS footnote A: 5-digit ZIP Code has been corrected.
00200000 USPS footnote B: City/State spelling has been corrected.
00400000 USPS footnote C: City/State/ZIP are invalid.
00800000 USPS footnote D: No ZIP+4 has been assigned.
00010000 USPS footnote E: ZIP Code has been assigned for multiple response.
00020000 USPS footnote F: Address not found in the dataset with City/State/ZIP provided.
00040000 USPS footnote G: Part of the firm was moved to address.
00080000 USPS footnote H: Secondary number was missing for this address.
00001000 USPS footnote I: Insufficient/incorrect address data supplied.
00002000 USPS footnote J: PO Box address used for dual address.
00004000 USPS footnote K: Non-PO Box address used for dual address.
00008000 USPS footnote L: Delivery address component has been changed.
00000100 USPS footnote M: Street name has been changed.
00000200 USPS footnote N: Delivery address has been standardised.
00000400 USPS footnote P: Delivery address is known by a preferred name.
00000800 USPS footnote R: Address is not in current data, but will be added in the future.
00000010 USPS footnote S: Secondary number does not match.
00000020 USPS footnote T: Address has magnet street syndrome (multiple).
00000040 USPS footnote U: City or PO name supplied was not an official last line name.
00000080 USPS footnote V: City or state could not be verified as corresponding to the ZIP code.
00000001 USPS footnote W: Address was identified as a small town default.
00000002 USPS footnote X: Address has a unique ZIP code default.
00000004 USPS footnote Z: Match made using ZIPMOVE data.
00000008 USPS footnote Q: Match has been made to a unique ZIP.
10000000 BSP assigned state as NSW
20000000 BSP assigned state as ACT
40000000 BSP assigned state as VIC
80000000 BSP assigned state as QLD
01000000 BSP assigned state as SA
02000000 BSP assigned state as WA
04000000 BSP assigned state as TAS
08000000 BSP assigned state as NT
10000000 Postal CodeOM not found.
20000000 Province not found.
40000000 Community not found.
80000000 Street name not found.
01000000 Street type not found or invalid.
02000000 Street direction not found or invalid.
04000000 Street suffix range error.
08000000 Street number not found or invalid.
00100000 Suite keyword invalid.
00200000 Suite number range error or exceeds 6 characters.
00400000 Route/box keyword not found.
00800000 Route service not found/range error.
00010000 Box number not found or invalid.
00020000 Delivery installation name not found.
00040000 Delivery installation keyword not found.
00080000 Delivery installation qualifier not found.
00001000 General delivery keyword not found.
00002000 Invalid '#' symbol in address.
00004000 Other/unknown reason for unmatched address.
00008000 Rural Route (RR) or Large Volume Receiver (LVR) address (addresses identified as RR or LVR may not be checked but still return valid matches).
00000100 Rural Route (RR) or Large Volume Receiver (LVR) address corrected.
00000200 Rural address questionable. The address may be valid, but appears to be inconsistent or missing key address elements.
00000400 Apartment address questionable. The address may be valid but appears to be inconsistent or missing key address elements.
10000000 Primary information in the input address was unmatched but has been included in the output address.
20000000 Secondary information in the input address was unmatched but has been included in the output address.
40000000 Unmatched additional secondary information in the input address has been included in the output address.
80000000 The address matched an alternative firm/organisation, but the input organisation was used in the output address.
01000000 The input street address matched a PO Box record in a unique ZIP code area. Confidence has been reduced to low.
02000000 The input PO Box matched a street record in a unique ZIP code area. Confidence has been reduced to low.
04000000 A street level match without primary information has been found in a unique ZIP code area. Confidence has been reduced to low.
08000000 Unidentified additional numeric information in the input address has been omitted from the output address.
00100000 USPS footnote Y: Input address matched a military record.
00200000 The address was DPV confirmed (for the purposes of CASS mailing discounts).
00400000 The address was DPV confirmed as a high-rise default but secondary information was not matched.
00800000 The address was DPV confirmed, but secondary number provided was not matched.
00010000 USPS footnote F1: matched ZIP+4 Military record.
00020000 USPS footnote G1: matched ZIP+4 General Delivery record.
00040000 USPS footnote U1: matched ZIP+4 unique zipcode record.
00080000 USPS footnote P3: invalid PO, RR, or HC box number.
00001000 USPS footnote AA: input address matched to ZIP+4 file.
00002000 USPS footnote A1: input address not matched to ZIP+4 file.
00004000 Business address improved using SuiteLink data.
00008000 Address updated using NCOALink data.
00000100 USPS footnote BB: input address fully matched (all components).
00000200 USPS footnote CC: primary number match but secondary number not matched (present but invalid).
00000400 USPS footnote N1: primary number match to high-rise or box type address, but secondary information missing.
00000800 USPS footnote M1: primary number missing from input address.
00000010 USPS footnote M3: supplied primary number invalid - could not confirm address.
00000020 USPS footnote P1: box type address (i.e. PO/RR/HC) missing box number.
00000040 USPS footnote RR: CMRA (Commercial Mail Receiving Agent) address match.
00000080 USPS footnote R1: CMRA (Commercial Mail Receiving Agent) address match, but secondary number not present.
00000001 DPV system is enabled at the point after the search.
00000002 DPV system has been disabled.
00000004 DPV search was a seed address, disabling the system from this point onwards until it is successfully unlocked.
